Question about Refrigerators
Hello, I have standing water on the inside bottom under the vegs drawers? Thx
  • Jerry Smith Apr 16, 2015
    Hi Jim McGrath, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Can you post the complete brand and model number.
  • 3 Answers
There is a small drain hole on the inside of your fridge at the back. That can be clogged or filled with ice. Take a syringe or small pipe and let warm/hot water run through there. You will see the water come out into the bowl that is on top of your compressor at the back of your fridge. If the water starts running through freely, the blockage has been removed. If the warm water doesn't help that much, it might be a blockage, rather than ice build up, for that you can take a tube and try blowing air through the hole. That should help your problem. For some model fridges there are modifications set out from the factories for the service agents. Contact a service agent for your specific make and model and make sure from them. Hope it helps
Posted on Apr 17, 2015
  • Petronella Diedericks
    Petronella Diedericks Apr 17, 2015
    Also, if your fridge is one of those with the set dial inside with numbers 1 - 6, don't set it higher than between 2 and 3, that also should help with excessive ice build up. If it has a display at the front, your fridge temp should be +2 and your freezer never lower than -16
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
SOURCE: water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Posted on Jun 24, 2009
  • 15 Answers
SOURCE: Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Posted on Jul 08, 2009
SOURCE: I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Posted on Jul 11, 2009
  • 10865 Answers
SOURCE: Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Posted on Aug 22, 2009
Samsung refrigerator
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
Water running down inside refrigerator into bottom veg drawer
What you have is a clogged defrost drain. Instead of the water going under the machine it is running down the backside of the wall. If ice is blocking the drain then after that is cleared yall can run a small wire off the heater and down into the hole to keep ice from forming at the drain hole:
Ice box service manual and more HERE
Jun 21, 2011 | Whirlpool 21.7 cu. ft. Top Freezer...
U-line UC02175 water inside pooling under veg drawer, icemaker supply turned off, no water in catch pan inside back
Well sounds like your ice maker evaporator drain hole is frozen, every time the unit goes into defrost cycle, water backs up and leaks down to the drawer. You can try turn off the refer for 48hrs with the doors open, most case it will reset by it self. If it is happening again in few weeks, then you evaporator drain pan heater is not working. Also make sure the doors are shut all the time.
Feb 03, 2010 | U-Line CO2075F-B Echelon Refrigerator Ice...
I have water standing below the veg. trays, not sure where it is coming. How do I find the drain lines.
The water comes from the accumulated moisture. Just
clean the drain at the back of the veg tray. Get you veg. tray out so you will find the drain.
Sep 25, 2009 | Refrigerators
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
