Question about Speed Drills
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
The Drill came with a phillips/screwdriver bit. I don't know how to insert it. I don't know what drill bits to buy and how to insert them either. My model doesn't have a chuck key or side handle.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Posted on Apr 15, 2015
Can't get bit key to release screw driver to replace with other drill bit.
just use two pairs of grips , one to hold the bit and the other to turn the chuck
Feb 27, 2011 | Black & Decker 3/8" Variable Speed...
How do i remove the bit from the drill
This drill has a 2-level chuck handle. one is slightly larger diameter, or is closer to drill body. It is fixed to the motor shaft. Smaller diameter, or forward one is the adjustment. Hold the rear/larger one stationary and twist the smaller/forward one as if you were opening a water bottle with a really tight lid.
Sep 17, 2010 | Black & Decker 3/8" Variable Speed...
I NEED A WIRING DIAGRAM FOR THE SWITCH ON AMODEL 7191 TYPE 3 , 3/8 B&D DRILL
i don't think you will find a diagram for the switch. find a parts schematic and order a new one. they aren't make to be fixed.
Aug 02, 2010 | Black & Decker 3/8" Variable Speed...
3/8 " corded reverable drill. the jaws will not close around bit
If the jaws of the drill no longer works, then, the drill chuck must be replaced. Take it off by turning the chuck
counterclockwise, and putting an open wrench at its neck to lock it. Then, after taking it off, you can now have it replaced.
Nov 25, 2009 | Black & Decker 3/8" Variable Speed...
How do I change my black & decker electric drill to go in reverse or forward? As you can see I'm tool challenged. Kathleen
The switch near the trigger that toggles left or right controls that.
Good luck with your project, Kathleen.
Oct 02, 2009 | Black & Decker 3/8" Variable Speed...
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
How to change the drill bit
there is a rippled edge close to the very tip of the drill and there is a key supplied with the drill with the corresponding ripples place key into the hole near tip of drill so ripples meet each other and turn key in an anticlockwise direction to loosen put in new drill bit re tighten in clockwise direction hope this helps if not please ask for more info glenn
Nov 23, 2008 | Black & Decker 3/8" Variable Speed...
Drills Logo
214 people viewed this question
Top Speed Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Speed Drill Expert? Answer questions, earn points and help others
