Question about Sony Audio Players & Recorders
Have a sony dav-hdx275 disc tray wont open and display reads( C 31 00)
    Master:
  • 269 Answers
SOURCE: Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, em.maciel@ibest.com.br
Posted on Aug 16, 2008
  • 18 Answers
SOURCE: Sony DAV-SB100 - Tray won't open
the only way to get it open is threw the inside of the system and i wouldn't advise you to do that unless you know something about electronics or if you are lucky try to unplug it for about 30 mins and see if it will reset itself and plug it back up, and when you plug it back up only press the eject button. good luck!!!!!
Posted on Dec 30, 2008
SOURCE: DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Posted on Mar 14, 2009
chipsandnuts
  • 70 Answers
SOURCE: display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Posted on Jul 03, 2009
tc3gs400
  • 14 Answers
SOURCE: how to play multi region disc in sony hometheatre dav-dz280
your player comes as a multi reader player..
Posted on Jan 12, 2010
HAVE A SONY DAV-HDX265 DISC TARY WONT OPEN AND DISPLAY READS (c 31 00)
Hi. If you are able to open, do so and check if you find a black rubber band that could have fallen off the tray. If you do just buy and replace. The band is is driven by some gears and helps open the tray and if it ages it gets damaged and cuts off. If the band is still intact, then see if the elasticity is still there and replace if there is no elasticity. If the band seems fine, then look at the gear near the end of the tray and try to open the tray manually.If you open the tray manually try see if there are broken or damaged gears. If non power the system and see if the tray closes. If it does then press the open button to see if it opens. If it does not, change the black rubber band that should work.
Aug 30, 2016 | Sony Audio Players & Recorders
How do I unjam a disc stuck in the 5xCD tray of a Sony DAV-C770 compact AV system?
If you experience difficulty with the disc tray opening or closing, follow these steps to try to resolve the issue.
  1. Turn off the power to the disc player or the stereo system, if the disc player does not have a separate POWER button.
  2. Unplug the power cord from the AC outlet.
  3. Verify there is nothing is blocking the tray from opening or closing.
  4. Let the disc player or the stereo system remain without power for approximately one minute.
  5. Plug the power cord back into the AC outlet.
  6. Turn on the power to the disc player or stereo system.
  7. Attempt to open or close the disc drawer or tray.
If the issue is still unresolved, service may be required.
this is direct from sony hope it helps
Dec 31, 2014 | Sony DAV-C770 System
Disc tray wont open
Get a paper clip and look at the face of the drive.. There is a small hole, insert the unfolded paper clip in the hole and the drive will release. Good luck
Apr 18, 2014 | Sony DAV-C450 System
Sony dav-dz555k home theatre system-dvd tray keeps opening and closing, wont read disc at all. have to manually push tray closed and change setting from dvd to something else to stop it.
You seem to be having a door sensor problem. When the CD tray closes a small switch under the loading tray shorts telling the microprocessor the door is closed and to stop the motor (either way when it opens or when it closes). A malfunction in this switch causes this symptom.
Mar 14, 2011 | Sony Audio Players & Recorders
I have a sony dvd player that has a stuck disc. Model number DAV-HDX275. The readout has a message "C31 00" displayed. Do you have any suggestions to remove the disk?
The only way to get this to eject is to open the case, Look carefully at the mechanism. Press eject and see what opart tries to unlock and assit it. The tray will then eject. It may be stuck because a piece iof the label is jamming the mechanism.
Please rate my help++++Thanks for using FIXYA
Jun 26, 2010 | Televison & Video
Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Jan 25, 2009 | Durabrand HT-3915 System
Aug 11, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony DAV-HDX275
Region Free DVD can be playback on all Sony DVD Players.
Jul 24, 2008 | Audio Players & Recorders
Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Jun 22, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
178 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
