Question about Bernina Sewing Machines
I am trying to gather a skirt with my 330 Bernina machine. I have the gathering foot on is there something else I need to add to the machine or adjustments to make to get it to gather?
  • Bernina Master
  • 12,511 Answers
Here is a Bernina video showing how to use the Gathering Foot:
Gathering foot 16 for professional shirring and gathering BERNINA
Posted on Apr 15, 2015
Why can't I reverse stitch properly on Bernina 1008 when using zipper foot?
please check that the foot is attached on the drop arm in the correct position as it sounds like the foot is not down far enough to reach the base plate I have had the same problem when you have more than one foot in your spares box eric
Dec 12, 2017 | Bernina Sewing Machines
I am trying to gather I have a gathering foot on but it isn't gathering please could you tell me what tension it should be on
Tension should not have a large affect on gathering other than one thread will lay on top of the fabric instead of both threads meeting in the middle of the fabric. There are several different kinds of gathering/ruffler feet, so it is difficult to address appropriately.
How To Use Gathering Foot
How to Use Gathering Foot 2 Ways The Sewing Rabbit
Gathering Foot VS Ruffler Foot Sewing Parts Online Everything Sewing...
Nov 06, 2017 | Sewing Machines
Why is my Bernina 440QE is "gathering" my stitches when I am just sewing fabric together. Aurifil top and bottom, and a 80/12 Micro Tex needle. The stitch is at 2.40, pressure at 47. Can you help?
The tensions on the machine may be too tight. You may need to loosen both, the upper tension and the bobbin tension. In addition, you may also try shortening the stitch length a bit.
http://www.howcast.com/videos/512592-how-to-prevent-puckering-sewing-machine/
http://www.threadsmagazine.com/item/6847/perfect-machine-tension-every-time
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjXrISW3LjPAhUJ-mMKHURnA54QFgg6MAU&url=http%3A%2F%2Fwww.amannusa.com%2Fpdf%2Fnahtkraeuslen_gb.pdf&usg=AFQjCNE-YAZ5WB1V7bFGptxZojumhoodMQ&cad=rja
Oct 01, 2016 | Bernina Sewing Machines
I am Lina van der Poel. The attachment to do gathering stich is something you attach to the machine underneath the needle that gather the material in small little pleats while stitching. I need the...
If you go on the manufacturers web site, you will possibly find the part number of the gathering foot and then you can Google it to find stockists who might post one to you.
Jan 28, 2015 | Sewing Machines
Bernina 1080 pleats the fabic of 1 layer on zig zag setting.I am trying to do the "cheats way " of gathering.Have adjusted the top tension ,changed thread/ needle.What can it be?
The fabric is tunneling? The pleat is forming the length of the line of stitches? http://crazylittleprojects.com/wp-content/uploads/2013/01/Z4.jpg Loosen the upper thread tension and increase the presser foot pressure and/or choose a flat soled foot, not an embroidery foot and/or add paper or other stabilizer on top of the fabric.
Or if the stitches are gathering up as you sew, go with it... that's what you're going to be doing anyhow, right? You can increase the amount of gathering by parking your thumb or forefinger hard against the needle plate behind the presser foot and allowing the fabric to pile up--- this is called "crimping" or "ease plus" and is commonly used for easing princess seams or sleeve heads. If it eases too much, clip the seam threads here and there and pat the fabric back out a little flatter, till it fits.
PS: If you like Gutermann poly threads, check the prices for Mara 100 at Wawak.com or similar pro sites. At Joann Fabric prices, you get an $8 spool of thread for $2.50 or less. Good stuff.
May 18, 2014 | Bernina Sewing Machines
Need to gather a skirt to fit a dress bodice don't remember settings
hi, have the machine set at the longest straight stitch length, usually 4 or 5. Then sew 2 rows of stitches side by side without reversing at either end. remember to always pull the bobbin threads up to gather and not the top one.
Jan 22, 2014 | Singer Sewing Machines
When i do gathers on my machine i use the largest sticth,but the gathers r hard to pull. y/
Stitch length of 4, loosen your top tension by half a number and always pull up the bobbin threads.
If you need to gather yards of fabric then get a gathering foot. Janome make one - it looks like this
This foot is for creating soft gathers in lightweight fabrics. The underside of the foot is raised behind the needle and has a thick bar in front of the needle to gather the fabric. This works great to create the gathers as you sew. You can also gather and attach a ruffle onto a flat piece of fabric simultaneously, run the flat fabric through the top groove of the foot and the underneath fabric is gathered and stitched to the top piece, you need to keep the bottom piece feeding smoothly though so it takes practice to guide it evenly. Once mastered it is great to ruffle on valances and cushion frills.
Other option is use a ruffler foot, these will make a little ruffle every 12, 6 or 1 stitch so give a set result, and to obtain a more dramatic gather. They look like this.
The arm of the foot with a C'shape sits over the needle bar of the machine so it is moved up and down to activate the device. The little blade at the front moves backwards at regular intervals forcing a "tuck" of fabric into the feed to be stitched. Again you can ruffle and stitch to straight fabric at once but it is an art to master.
The weight of the fabric you are gathering is obviously the key variable, ginghams and poplins are lightweight so gather easily but if you need to gather something heavy like cordoroy it is going to be a battle and threads may break. If so, stitch two lines of gathers and don't try to do long runs, you'll just break a thread and have to start over.
Another good way is to zig zag over a length of perle cotton, taking care not to actually stitch the pearle at all. You can then gather up the fabric along it, this works well for heavier weights.
Oct 22, 2011 | Janome Memory Craft 9000 Computerized...
Does the XL 3200 have a gathering stitch?
You will need a gathering foot, a shirring foot or a ruffler - http://www.sewingmachine-sales.co.uk/sewing_machine_info/video/sewing-machine-feet.php
You can however, gather without these accessories.
Lay crochet thread down the line you want to gather and zig-zag over it anchoring one end and then pull up the gathers.
Another method is to make long stitches and pull the thread to gather.
Make a sample with the same fabric you will be gathering to see which technique works best for you.
Mar 04, 2010 | Sewing Machines
Gathering foot Not Gathering.
check the amount of pressure on foot, it might be too much for the type of material, that sometimes makes it gather
Jan 20, 2008 | Brother 1034D Mechanical Sewing Machine
Sewing Machines Logo
83 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
