Question about Kitchen Appliances - Others
How long will plain pop corn stay fresh, once it's been popped.
Nickstar19
  • 417 Answers
SOURCE: Pop corn jamming in the kettle
this happens if you put took much in at a time
Posted on Jul 17, 2008
  • 2976 Answers
SOURCE: cooking instructions
Corn will not pop without oil, it will just burn on one side.
Posted on Feb 21, 2009
  • 41 Answers
SOURCE: the wire in my stir crazy pop corn popper is broke
you can replace by a stainless steel rod
Posted on Oct 05, 2009
  • 30 Answers
SOURCE: How much pop corn and how much oil in the 4 oz
It all depends on the model you have. If you have a CCP-509 or 510 it takes 1 TBSP of OIL and 1/2 popping corn.
You can call 1-920-347-9122 if you need a manual.
Posted on Oct 30, 2009
cautionflag1
  • 116 Answers
SOURCE: need isntruction manual for retro
I couldn't come up with the manual, but did come up with the company. They have a toll free number listed, I would try that. I tried their website and it wasn't operating...so that isn't a good sign. But you might have better luck on the phone.
Hope this helps
The Helman Group, Ltd. 1621 Beacon Pl Oxnard, CA 93033-2452 Phone: (805)487-7772 Fax: (805)487-9975 Tollfree: (800)217-1958 Email this Company www.helmangroup.com
Company Description: blank Key Personnel: Name Title Andrew Helman Pres. Barry Helman CEO Coyo Ortiz Acct. Rec. Mgr. Mike Rochkind VP, Gen. Mgr. Wendi Tidwell Traffic Mgr.
Posted on Jan 21, 2011
Testimonial: "Thanks for being so fast, This was helpful"
Don't have a manual need to know how to operate Do I add oil or butter in bottom with the corn if so how much?
the ratio for popping corn with oil is three parts corn to one part oil . So a 6 oz kettle you would use 6 oz of corn seed to 2 oz of oil. Don't use butter to pop, it will burn.
Apr 27, 2016 | Kitchen Appliances - Others
The unit only pops half of the popcorn
The symptoms of only pops half the popcorn is a hard one to trouble shoot.
1.Check your popcorn, old popcorn dries out. As it loses moisture its ability to pop is reduced. Popcorn only lasts about 90 days after opening the air tight packaging.
2. If it is a oil popper, make sure the stirring rod is turning during the popping cycle. They sometimes can stir, but once the popping starts the pressure of the corn can stall a motor. This results in the first half popping, and the second half burning on the bottom.
3. Popper is too cold. This has symptoms of a long, long popping cycle, and half the corn popping the other half just turning brown. Some machines had adjustable thermostats inclosed, most home units do not. Letting it pre-heat longer does not help, the temperature is controlled by a thermo-stat.
Mar 07, 2013 | Kitchen Appliances - Others
ALL THE KERNELS ARE NOT POPPING
There are several possible culprits for your Kernel Caper.
1) You may need to add a little more oil to the kettle. Let it come to full heat--just as soon as the oil starts to smoke.
2) The corn you are using must be reasonable fresh and have sufficient moisture to pop the kernel. You can try putting 1 tsp/1 lb of corn in a ziploc bag or screw top bottle. Leave for 24 to 48 hrs to let the corn absorb the moisture.
3) Finally, due to the small size of the popping kettle some kernels will be thrown from the kettle from other kernels popping open.
This is a great little popper. You might have some luck decreasing the size of your batch--reduce your oil and corn by 1/4 each.
Good Luck
Sep 24, 2010 | Maximatic EPM450 Popcorn Maker
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
Feb 04, 2010 | Walter Drake Old Fashion Popcorn Maker
How much oil or corn do you use in the Back to Basics Pop Corn Popper for the stove
unless you have the instruction manual, only trial-and-error will tell you. Start with 2 tablespoons of oil and 1/2 cup of corn kernals. If there is oil left after the corn is popped, decrease the amount of oil by a teaspoon. If the popped corn is burned, increase the oil by a teaspoon. As for the corn, if the pot is full when the popping is done, 1/2 cup is the right amount. If the popped corn over flows, 1/2 cup is too much. Vary the oil and corn until you get it right. Good luck! I love popcorn, so I wish you the best.
Feb 02, 2010 | Back to Basics 6112304 Popcorn Maker
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Half the Kernals spit out uncooked
It coud be 2 things. Either a low grade of popping corn, or old popping corn. Hot air poppers blow the same temperature, until you shut them off. Although the better grades of popping corn cost a good amount more, you don't throw half of it away. Once the popping corn container has been opened, you should use it up within about 3 months. The internal moisture content is what determines whether corn will pop or not. Too much or too little moisture will not allow the corn to pop.
Aug 23, 2009 | Toastess Hot-Air Corn Popper Popcorn Maker
Jul 13, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Popcorn
Cuisinart makes fresh, crunchy, homemade popcorn fast, easy¿.and healthy! The Cuisinart Popcorn Maker pops up to 10 cups of popcorn in under 5 minutes, and lets popcorn lovers decide just how much, and what kind, of popcorn, oil and flavoring to use. Popcorn pops right into a clear plastic bowl that flips to serve, and both bowl and poping plate go into the dishwasher.
Feb 18, 2008 | Kitchen Appliances - Others
No user manual
keep the lid on, you can put butter up top to melt
Dec 02, 2007 | West Bend 82306 Stir Crazy® Popcorn...
Kitchen Appliances - Others Logo
213 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
