Question about Jeep 2003 Liberty Sport 3.7 V6
Truck starts fine cold and the longer it runs the more it miss fires i pulled p0300 0302 0303.
While looking at live data noticed engine coolant temp going from normal around 200 to -50 or around that. i changed the sensor and no change in the live data. im lost!!!
    Top Expert:
  • Jeep Master
  • 45,573 Answers
The codes refer to random misfires
misfires come from plugs, ht leads , fuel pressure , injectors, coils
As it heats up I suspect that you have a problem with an electronic component breaking down such as a coil/s, ignition module, fuel pump, or injectors
Posted on Jun 11, 2015
Dying, not starting after it's been warmed up. Runs beautiful on cold engine. Replaced plugs, wire, cap, rotor and crank position sensor, no luck.
Your car cold start valve puts more gas into the system keeping your engine running higher RPM. When you car warms up, the cold start valve will stop working and your car RPM will drop. What you could have is a vacuum hose disconnected which puts more air into your engine - therefore when you press on the gas pedal, your engine would shut off or you find lack of power and then shut off.
Mar 27, 2015 | Cars & Trucks
For the last 3 weeks my truck wont start if the temp out side is 45 or below.But when it is warm out it fires rite up. Anyone have a ideal what,s going on?
You would need to test your fuel pressure and use a scan tool to look at the data for the coolant and Intake air temp sensor to see if they are acurate. The engine requires more fuel when the engine gets that cold and it sounds like it's not getting it.
Nov 08, 2014 | Cars & Trucks
Restarting problems
The first thing you need to check is your coolant level. If it is low then the Coolant Temperature Sensor will not be in coolant, but in air, or steam, but either way it will signal the computer that the engine is cold and therefore deliver a very rich fuel mixture, flooding the engine. It could also be the engine temp sensor itself, sending incorrect temp readings to the computer. Either way once the engine has been allowed to cool down, the false signal to the computer will be correct. If the truck is emitting black smoke once it warms up, then this would be another sign that the Engine temp sensor is bad.
Apr 14, 2014 | 2000 Ford F250 Super Duty Crew Cabs
Hello i have a 2000 toyota 4runner limited 4x4 . i live in maine and when i start the truck up in the morning to go to work, after the truck warms up it puts out nice heat. but after i drive it for 10...
bleed cooling system.run engine with red cap off till up to temp.replace cap before turning off engine.might have to add more coolant while running.
Feb 13, 2011 | 2000 Toyota 4Runner
1997 F-350 Ford Powerstroke4x4 Crew Cab Diesel 83k miles. Truck runs fine while cold. When it starts reaching normal operating temp it starts missing and loosing power when accelerating. Truck idles fine....
Have you changed your oil? Rotella 15W-40. These engines really don't like old oil. It becomes too thick for the injection pump to work correctly. Another possibility is a bad cam sensor on the front of the motor. Most engines call this the crank sensor but on this engine you have to look it up as a cam sensor.
Sep 29, 2009 | Ford F-350 Cars & Trucks
Truck runs rough at start-up in the mornings
If this happens only when the engine is cold or cool, I would suspect a coolant temperature senor that has lost its calibration.
One way to check would be to have the engine controller scanned when the engine is cool then cold.
The coolant temperature should be the same as the intake air temperature. If the readings are not close to one another, change the coolant sensor.
The coolant temp sensor controls the fuel mixture when the engine is cold, normal or hot.
Good luck, let me know.
Regards,
Apr 07, 2009 | 2001 GMC Yukon Denali
Missing when first started. Stops when warms up.
016 Engine Misfire Misfire Scan Data Find someone who knows what scan data is an knows how to use it .Intake manifold vacuum leak .
Rough Running When Cold GMC Yukon
Jun 19, 2017 | 1998 GMC Sonoma
Jeep 2003 Liberty Sport 3.7 V6 Logo
99 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Bill Boyd
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
