Question about Garden
Where can I get parts for this product - Garden
Need an owners manual
I don't have a manual for that product.
Garden Sun appears to a Chinese company direct-selling patio heater product through distributors in US.
http://gardensun.en.made-in-china.com/
There are no product manuals on site.
There is a link for service.
Probably the link for service is about SALES, and nothing to do with faulty products, or repair parts.
I doubt there are repair parts of any sort for the heater.
This type product usually has 30-90 day warranty through the seller where product is simply replaced for new one.
Afterward there are no parts or general repair protocol, and short time later, the product is discontinued and new model takes its place.
Oct 01, 2012 | Stainless Garden Sun Steel Propane Patio...
Tip
How to Find Shark Parts and Accessories
There seems to be many people that are looking for parts and accessories for their Shark products. Shark does have a website where they sell parts and accessories for their products.
Whether you are looking for parts for you Steam product, Upright vacuum, Garment care product, or your hand or cordless vacuum, you can find any of the available parts here.
Go to http://www.sharkclean.com
Then at the top right under the search box, hover over the parts and accessories tab.
A drop down menu will appear and you can choose which product you want to see the parts for.
Click on that product and you will then see separate boxes for parts and accessories for all of the products in that category.
Click on the product you have and then you will see a list of parts or a list of accessories available for that product.
There are many parts available for their products, but I would not say that they have available every part that could possibly break.
There no parts that pertain to the heating function, so if your product stops making steam for instance, there are no parts that can help you fix that.
Broken handles are fixable and are there. Replacement heads and replacement head coverings are there as would be expected.
If you are in need of parts to fix a product that is not heating, I would suggest looking for used products on Ebay or something like that. Also advertising for a used product may also get you the parts you need...unless of course they are selling it because of the same problem that you had...make sure to check that out first.
heatman101
Also checkout these other related tips...
http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
http://www.fixya.com/support/r6740629-shark_steam_pocket_mop_cleaning_problems
on Nov 18, 2010 | Vacuums
Camshaft sencer
you have to remove the power steering pump,
1- remove the belt
2- turn power steering pulley to see hidden bolt behind the pulley
3- you do not need to move the hoses
4- there is a 10mm bolt hold the sensor,
5- after removing the bolt just twist back and forth to loosen it and pull it out,disconnect the wiring harness.
these are the price at rockauto.com
us.gif ca.gif pc254t_primary.jpg$22.99
STANDARD MOTOR PRODUCTS Part # PC254 {#12567650, 24507588}
us.gif ca.gif pc254_primary.jpg$28.89
DELPHI Part # SS10044
us.gif ca.gif ss10044a.jpg$37.89
AIRTEX Part # 5S1239 {#12567650, 24507588, SU1368}
us.gif ca.gif 5s1239.jpg$38.79
ACDELCO Part # 213937 {#12567650}
us.gif ca.gif SENSOR,CM/SHF POSN213-937_primary.jpg$43.79
/uploadswith image
May 21, 2012 | 1999 Chevrolet Lumina
SIMMONS JUVENILE PRODUCTS 5017
Products America has parts and instructions manuals for many different manufactured cribs. Please review our website www.productsamerica.com to determine what hardware you are missing. You can also email us at parts@productsamerica.com for the assembly instructions.
Apr 08, 2012 | Simmons Mattress Crib 'n More
I would like a sainless steel blade for a a model number cl-003ap1
Replacement parts for Jack Lanne Power Juicers are available on-line here:
https://www.unitycart.com/pjss/parts/parts_classic.asp
The menu is set up by product name rather than by product number. Select your product and a list of available parts will be made available.
Mar 19, 2011 | Jack Lalanne Power Juicer (Stainless...
Need the specs for the Homedics ss-5010 power adaptor
Product Attributes
Product attributeProduct Line: SoundSpa
Product attributeProduct Model: SS-5010
Product Summary
Manufacturer: Homedics
Mfg Part#: SS-5010
Buy.com Sku: 211467114
UPC: 031262038029
UPC 14: 00031262038029
Package Weight: 1.9 lbs
Buy.com Sales Rank: 64081
Advertisement middle
Features
Product Type Desktop Clock Radio
Manufacturer Part Number SS-5010
Manufacturer Website Address www.homedics.com
Manufacturer HoMedics EMEA
Product Model SS-5010
Product Name SoundSpa Premier SS-5010 Clock Radio
Product Line SoundSpa
Brand Name HoMedics
Frequency Band/Bandwidth AM/ FM
Tech Specs
Brand Name HoMedics
Frequency Band/Bandwidth AM/FM
Feb 13, 2011 | Audio Players & Recorders
It is possible to change just the rubber seal on the pump on Fisher & Pakel washer?
DO NOT continue to use the machine with a leaking pump. The pump can short-out and kill the controller board, which turns a $60 repair into a $250 repair
When you purchase any new Fisher & Paykel whiteware product for personal or consumer use you automatically receive a one year limited warranty covering parts and labor for servicing within the 48 mainland United States, Hawaii, Washington DC and Canada. If your product qualifies, you also receive an additional 9 year parts only warranty on the Direct Drive motor part only. This additional 9 year warranty commences on the day following the expiry of the one year limited warranty and excludes the Rotor Position Sensor, motor controller and labor.
In Alaska the limited warranty, and, if your product qualifies. additional 9 year Direct Drive motor part only warranty (excluding the Rotor Position Sensor, motor controller and labor) is the same except that you must pay to ship the product to the service shop or the service technician's travel to your home. Products for use in Canada must be purchased through the Canadian distribution channel to ensure regulatory compliance.
If the product is installed in a motor vehicle, boat or similar mobile facility, you receive the same one year limited warranty, and, if your product qualifies, additional 9 year Direct Drive motor part only warranty (excluding the Rotor Position Sensor, motor controller and labor) but you must bring the vehicle, boat or mobile facility containing the product to the service shop at your expense or pay the service technician's travel to the location of the product.
Dec 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi, I have purchased a 12v Peg Perego Desert Tenere which needs some new body parts, does anyone know where i can purchase these from please?
This is straight from the website FAQ
Where can I buy spare parts for my product?
You can buy spare parts on our website www.pegperego.com or by calling our customer service department 1-800-728-2108 for toys or 1-800-671-1701 for juvenile products.
But I seriously doubt they will have body parts. You may just have to watch Ebay or Craigslist. Most of these companies would rather you buy another product new than sell too many replacment parts.
May 03, 2009 | Toys
Gitzo G1258 tripod
I still don't know if it's a common problem, or why it occurred, but I did find the link to Gitzo spare parts...
http://www.gitzo.com/Jahia/spareparts/site/gitzo
Jun 27, 2008 | Gitzo Photography
Garden Logo
305 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
