Question about Fishman Audio Players & Recorders
Need a schematic for a Fisman Solo 220 amp
2nd channel not working
    Top Expert:
  • Fishman Master
  • 3,107 Answers
Best bet is to contact Fishman directly-
http://www.fishman.com/contact
Posted on Jul 15, 2015
MACKIE SR24.4 MIXER, ONLY 1 CHANNEL WORKING ON PA
First, I would make sure the mute buttons are not on. Then I would also make sure that none of the solo buttons are on. If one is pushed in, only that channel will work.
Mar 03, 2013 | Music
Problems with fishman solo amp
Just boughtcSA220. The XRL on No. 1 channel not working. Tried to different mice.
Aug 20, 2012 | Fishman Solo Amplifier (with )
Channel 16 to 24 the "solo" buttons do not
This is probably a loose or damaged cable within. These channels I believe are grouped in groups of eight, so two groups would be dead for this function.
Here is your schematic:
http://elektrotanya.com/mackie_1642-vlz-pro_full-sm.rar/download.html
Feb 01, 2011 | Mackie 1642-vlz3 (16-ch 4-bus Compact...
I have Mackie mixer cfx12 all the channels work except for channels 2 & 3, I turn the pre amp trim pot all the way up but no input is present, I also tried solo PFL for these two channels and no...
I suspect one of the upfront IC amps has been damaged. This can happen if people power the mixer from a receptacle that is different from where other connected equipment is powered such as amp. For example, mixer is at one end of the hall and other inouts such as an output of a guitar amp is plugged in. If a ground fault or spike occurs, teh ground bounce can exceed the common mode voltage of the input amps.
In your case, the inpout amps are discrete transistor types.
A voltage surge into the inputs of your unit would LIKELY pop two bypass caps that are 330pf. For channel 2 these are C205 and C206. Check those for shorts.
VERIFY audio is available at the "send" (tip) of the channel insert connector... this verifies the preamp stage. You can PROBABLY plug a set of headphones in to check this... ONLY one side will have sound of course. Verify this is a good test by checking a working channel. The level will be quite low and we are looking for just some signal.
IF you do have signal on the channel insert send which is the "tip" of the channel insert with the trim turned up, let me know and I will check the schematic for the next thing to check farther down the line.
Sep 15, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Jun 03, 2010 | Behringer EUROPOWER EP2500 Amplifier
Why did one of my speakers stop playing i have 2 solo baric l7. i dnt think it's the speaker but i dnt know what it is help help help sos
Check the speaker fuse (inside Pwr Amp), try to connect to the other channel of the Power Amp, check RCA cable from source( Player) connection. There could be one channel of the power amp defected too
Apr 13, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What wires do i need to hook up 2 kicker solobaric s15l7 to a car
You will need the amp wires. Red Positive to battery, Black negative from amp ground to unpainted car body surface, and the blue remote wire that goes from amp to remote wire on back of cd deck.
Then you will need the rca cables from rear output of cd player to the amp.
Then just the positive and negative wire from speaker to amp. Use Speaker Positive wire to Amp Right Channel Positive
And speaker negative wire to amp Left Channel Legative wire.
That is it.
Nov 17, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
High wattage car stereo
positive (1 guage) from main battery to second battery positive terminal. hook all amps positive to second battery and hook 2nd battery ground to frame of car (where amp is now grounded) if you have a 2nd battery a cap is a waste of money. make sure all grounds (battery and amps) are together on same ground point of car, do not ground amps to battery - ground everything to 1 spot on the frame or body of the car ! - yes you can pigtail remote leads.
Jan 01, 2009 | Kicker KX650.4 Car Audio Amplifier
Is it good or not
HI qq_lando,
Yes, you can get good bass from this setup. The Boos amp can handle 1 ohm but no less. You should be fine if your using one, no more than 2 kickers. You will need to configure the wires different for 2. Direct connect + to + and - to -. I must suggest if you have Dual Voice coil to wire your Solo X in series to keep the Ohms up. Main thing to remember is keep it below 8 ohm and above 1 ohm total impedance
Nov 09, 2007 | Car Audio & Video
190 people viewed this question
Top Fishman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fishman Audio Player and Recorder Expert? Answer questions, earn points and help others
