Question about LG Flatron Computers & Internet
I got out of range 53.8khz/85 hz - Flatron LG Computers & Internet
5 Suggested Answers
  • 55 Answers
SOURCE: I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Posted on Jan 05, 2010
budmrtn
  • 11361 Answers
SOURCE: Monitor says Analog RGB 1024 x 768 / 85 Hz Out of
You need to set your PC video output to the native resolution of this monitor, 1440x900 @60Hz.
Posted on Apr 03, 2010
  • 5 Answers
SOURCE: Out of Range HFreq 91
Lower your resolution step by step until it is in range.
Posted on May 27, 2011
jerardi
  • 14161 Answers
SOURCE: I get (D-sub out of range 53.6 k hz / 85 h z) how
this is a how to video on how to fix the video out of range error.
Posted on Feb 06, 2015
How can I adjust the height of the HP LP2465 24" LCD Monitor?
MOST OF THE TIME THEY WILL NOT ADJUST UP AND DOWN. LOOK FOR A SMALL LEVEL AT THE BOTTOM OF THE BASE OR JUST BEFORE THE BASE. I JUST GOOGLE IT AND FOUND PICTURE OF IT.
May 21, 2014 | HP LP2465 24" LCD Monitor
Why won't my d915gag keep it.s monitor settings? always reboots at 85 hz.
Go to this link for a check of drivers and other settings and trouble shooting.
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d915gag
Mar 17, 2012 | Intel Computers & Internet
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
Out of Range HFreq 91 KHZ and V Freq 85 HZ How do I fix?
May 27, 2011 | ViewSonic Graphic VG2021m LCD Monitor
Wattage
I have the following specs for you
Basically 150watts per channel using two channels , or 75watts using all four
Here goes:
  • 4 Channel Mosfet Amplifier
  • Advanced Overload and Thermal Protection
  • Metal Film Capacitors/Resistors In Signal Path
  • Frequency Response +/-1dB, 20Hz to 20 kHZ
  • Signal to Noise Ratio (A-weighted) >100dB
  • Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
  • Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
  • Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
  • IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
  • Minimum Load when Bridged 2 Ohms
  • Minimum Load per Channel 1 Ohm
  • Input Signal Voltage Range 0.1 volts to 2 volts
  • Crossover Type Resisitor Network, Linkwitz Riley,
  • Highpass/Lowpass
  • Crossover Slope 24 dB per octave
  • Crossover Frequency Range 20-550Hz
  • Factory Crossover Setting 85 Hz
  • Auxilary Output Channels 2
  • Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
  • Bass Boost 0- to +18dB @ 45 hZ
  • Power Supply Voltage 10Vdc to 15.5Vdc
  • Recommended Fuse 40 amp
Dimensions 12.25L x 9.25W x 2.10H
May 23, 2010 | Car Audio & Video
Monitor says Analog RGB 1024 x 768 / 85 Hz Out of Range
install an AGP card into an AGP slot. use 8X AGP card then you can see high resolution because internal display card does not support to high resolution
Apr 02, 2010 | Xerox XR619DW Monitor
Jan 05, 2010 | KDS Computers & Internet
Monitor problems
Try setting your resolution lower via the control panel; it appears the resolution picked by Windows is beyond the monitor's capabilities.
Dec 13, 2008 | LG Computers & Internet
Computers & Internet Logo
53 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
