Question about Flojet Pump D2131I5011A
New pump-pump works fine for 2 seconds--loses pressure--spray goes from 10-12 ft to zero...wait for pressure to build back up and works fine for 2 sec....start over....pump unusable like this
Attached to a becknoll 25 gal sprayer
  • Flojet Master
  • 1,631 Answers
Air leak somewhere between the pump and the spray tip (s).
that will incllude the 25 gallon tank as a possible place to check for leaks!
Posted on Apr 23, 2015
Security light flashing,
battery going bad in key.. need new battery and reprogramed to security system..
Jan 02, 2014 | 1986 Nissan 300ZX
Starts then dies & won't restart
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
report back
Aug 22, 2011 | 2005 Ford Expedition
Why do I lose pressure while spraying. The air comes and goes. I have to wait for the pressure to build back up to spray again.
Well, either a system leak or your compressor does not have the capacity for the air usage of the gun. Spray guns have high air consumption.
Oct 10, 2010 | Campbell Hausfeld Air Tools & Compressors
I get DE back into my pump strainer and I only can filter for 2 to 3 hours before pressure is up to 20 to 25 lbs and I have to use bump handle to start filter again with results
The de coming back into the pump isnt anything serious, there may be a small air leak causing the water in the filter to drain into the pump.
As far as having to bump every couple of hours... is the pool really dirty?
Is your pressure gauge broken? Turn off the pump, does the gauge drop to zero? Alot of times they dont drop to zero, so when you hit 25psi it may really only be 15. Happens alot actually.
If pool is clean and clear and the gauge is fine... have you ever taken apart the filter and cleaned the de fingers? If not, i would take it apart, rinse all of the fingers and then let them soak over night in a filter cleaner solution. This cleans them much better then a plain garden hose spray. After they soak, spray them down again, add new de and you should be good to go....
Aug 15, 2010 | Hayward EC-40 DE Pool Filter with pump
Not enough pressure coming out
Usually this mean's you have lost pressure from one of the three cylinders. When you let off the trigger, the other 1-2 cylinders build pressure, as soon as you begin flow, then you're only running on 1 or 2 cylinders instead of three. This is usually caused by clogged check valves. It can also be caused by a faulty pressure regulator.
Jul 19, 2010 | Campbell Hausfeld 2000 Psi Gas Pressure...
The spray stream is not consistent. After 2 - 3
The pump cycles to keep the pressure constant. It could be the impeller---they sell special ones to use with nonaqueous sprays--ie petroleum based. If petro was used at some time, the impeller might be bad.
Mar 01, 2010 | Northstar ATV Broadcast Spot Sprayer 16...
Hi, back again. Changed the fuel filter and a new
No fuel pump reset switch on a Jimmy. If your pressure goes up to normal, then drops back down after 2 seconds, you need a new fuel pump as the return is not working correctly to keep fuel in the lines.
Jun 29, 2009 | 1999 GMC Jimmy
Saab 2.2tid car loses all power when warm, rev counter goes to zero
Check fuel feed is ok and fuel pump pressure also check cold start injector could be running on this til warm.
Sep 16, 2008 | 1999 Saab 9-5
Losing water pressure in pump?
Shellybabe, these GE dishwasher pumps have a habit of sticking when not in use for a while. It sounds like you have been washing but not good. If you remove the toe panel (lower) you will see the pump motor in the center. If the vanes in the back center of the motor turn freely, your pump is not stuck. If they wont turn, put pressure on them until the pump frees up. You also want to make sure that the fill valve is letting in enough water. The water should be just below the heating element after the initial fill. If you are not sure try adding 2 addition quarts of water to the machine after the initial fill and see if the circulation is better. Remember to unplug or kill the power to the dishwasher when checking the motor vanes...Catriver..post back.
Oct 31, 2006 | GE 25 in. GSC3200Z Free-standing...
Flojet Pump D2131I5011A Logo
479 people viewed this question
Top Flojet Plumbing Experts
Andrew Taylor
Andrew Taylor
richie46
Bill Boyd
Are you a Flojet Plumbing Expert? Answer questions, earn points and help others
