Question about Mantis Garden
How to fix mantis tiller that won't start? - Mantis Garden
boscia
  • 163 Answers
SOURCE: Mantis Tiller
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
  • 45 Answers
SOURCE: 2 cycle mantis tiller leaks gas thru the carb. -
if it leaks gas,it can **** air.you have to find out whats leaking and stop it.
Posted on Apr 29, 2009
SOURCE: trouble starting old Mantis tiller 9012 - don't have a manuel -
Mantis has the owners manuals in pdf format available for download on its website. The tillers are here (I hope the link to the tiller group works...if not, just go to the main site and look for "owners manuals" link.
Also, you can call a number and get a representative who usually can help at the numbers listed there, find authorized service people if its not something you can do yourself, order parts and find detailed schematics in the owners manuals. My dog actually ate mine. LOL. But they are free, the owners manuals, unlike other places that charge you for them like they were a "part".
http://mantis.com/owners_manual_library-swell2_tiller_engine.asp?cat=8
Posted on May 18, 2009
  • 15 Answers
SOURCE: Mantis tiller will start and idle, but once you
Check the exhaust side of the tiller. There are 3 screws on the muffler cover that need to be removed, then there is a cover on the spark arrestor that also has 3 screws to remove. Inside this is a small screen (the spark arrestor). Take it out and clean it with a good solvent (I use carb cleaner). This is the easiest and least expensive fix.
If this doesn't work you may need to rebuild the carb. I have found it is easier and costs about the same thing to just replace the complete carb.
The company will tell you to make sure you always run the carb dry before storage, but I have NEVER done that as I believe it dries out the gaskets. I just use STA-BIL gasoline stabilizer before I store it for the Winter and keep it setting level in storage.
Posted on Jun 03, 2009
Dusterz
  • 46 Answers
SOURCE: Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Posted on Jun 06, 2010
How to fix a mantis tiller that won't start
check the exhaust screen if it gets plugged with burnt(soot) /unburnt oil it will not let engine start
Apr 24, 2015 | Mantis 2-Cycle Tiller
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Mantis tiller won t start
-Clogged fuel line.
Good luck
Mai
Aug 09, 2014 | Mantis Garden
MDT Tiller starts and runs but tines won't turn
-Won out drive or driven gears.
Good luck
Mai
Jun 28, 2014 | Mantis 2-Cycle Tiller
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
Starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Jun 20, 2012 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I have a Mantis Tiller. It starts but has no torq...
possibly the (muffler) is plugged with carbon. happens when too much oil is used
May 19, 2010 | Mantis Tiller
Trouble starting old Mantis tiller 9012 - don't have a manuel -
May 16, 2009 | Mantis Tiller
Garden Logo
88 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
