How do remove to clean cover - Office Equipment & Supplies
  • 1,602 Answers
Spray your cleaner on a rag and wipe it down.
micro fiber or cotton rag
before removing the cover, we would need to know the following information
manufacturer
make
model
Posted on Apr 15, 2015
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
Replace valve cover gaskets
Remove bolts for valve covers. Remove cand clean covers. Remove and clean old gasket from heads. Use gasket shelack to place new gaskets into place(easier to place on the covers) Reinstall valve covers with gaskets in place. Reinstall bolts. Done.
Jun 12, 2014 | Vehicle Parts & Accessories
Where is thermofuse and thermistor located
The thermofuse and the thermistor is located in the fusing unit.Open the front cover,remove 1 screw and pull out the fusing unit(the left exit cover must open).Remove 2 screws and the unit front cover.Remove 2 screws and the upper cover,remove the harness from the harness guide,unplug the connectors of the two thermistors.Remove one screw,shoulder screw and the harness guide,remove one screw and the thermoswitch cord,remove 2 screws and the temperature detector assy.Using a soft cloth dampened with alcohol or oil,wipe clean the 2 thermistors.Verify a continuity of the thermoswitch and clean using a soft cloth dampened with alcohol,wipe clean the thermoswitch.99% the problem is a thermofuse.
Dec 17, 2012 | Minolta EP4000/5000 CS/PRO Copier
Need to replace valve cover gasket on 01 pt cruiser
This procedure takes approx 3 hours.You have to remove upper intake manifold and cylinder head cover,in order to replace valve cover gasket.
Its a huge procedure,but can be done easily.
Click the link below and follow step by step details.
http://technoanswers.blogspot.in/2012/06/valve-cover-gasket-removal-guide.html
This will help.
Thanks.
Jun 27, 2012 | 2001 Chrysler PT Cruiser
How to remove the cover to clean the Cyclone 20" fan?
Removing the cover is not actually required.
You may blow the whole fan clean with compressed air or a compressor.
In case you need to remove the cover, just twist it around and a pull it. It will come off.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Oct 18, 2010 | Dryers
How do I remove the screen to access and clean the picture tubes and mirror? Pioneer SD533hd5
Before starting, it is a good idea to disconnect the power cord for your TV from the AC wall socket or power bar. Remove the back cover from the TV. Unscrew and remove all the wood screws holding the back cover on. Grasp the bottom portion of the back cover and pull straight back approximately 4 inches. You may require assistance from another person if you are of small stature. There are two plastic tubular portions at the bottom of the back cover that insert into the particle board enclosure and if you don't pull straight back, you risk damaging the back cover and or the enclosure. The mirror is fastened inside the back cover and will come out at the same time. You will then have access to the CRT lenses and the mirror for cleaning. I would not recommend removing the mirror from the back cover for cleaning. It can be done while in place using a clean, soft, lint free cloth and a very mild soap and water solution. Just be certain not to leave any streaks. The lenses can be cleaned with a lint free cloth and alcohol or a camera lens cleaning tool. Take care not to touch the lenses with your fingers. See web link for lens cleaning tool http://www.opticsplanet.net/carson-lenspen-cleaning-tool.html .
Jan 12, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
How do i clean my window type aircon?do i need a technician or can i do it myself?
Yes you can do this . Remove this out the window, remove all the screws around the outside cover and lift off the 1-piece cover sides /top and start to clean .Also remove the cover on top of the back coil and clean this real good..
Dec 05, 2009 | LG Heat cool Window Air Conditioner
Good morning, I need to clean inside of my Toshiba 50A60 model tv screen, I do you remove screen?
Yes I Had The Same problem , if your handy with fixing things this will
work.
Step 1- unplug the TV from wall socket
Step 2- disconnect all devices like VCR's DVD Players from the TV
Step 3- remove the speaker covers from the TV
Step 4 - There are 14 screws on front cover, remove these with a
Philips driver, set cover aside
clean with soft brush and wash with water
Step 5- Gently raise the cover straight up to release it from its supports
Once cleared from supports , remove the cover.
Tips- Make sure you don't scratch any of the screens or CRTs
You can clean the mirror with any glass cleaner, make sure to wipe it
clean , water and vinegar does a good job to eliminate streaks.
Use a soft duster to clean the dust from the circut boards
Tip - Remember take it easy when cleaning
When your finished cleaning, just reverse the steps
It Worked for Me
Sep 30, 2009 | Toshiba 50A60 50" Rear Projection...
Need to remove screen cover
you have to remove the back of the tv to clean the inside screen.
Apr 29, 2009 | Toshiba 57H82 57" Rear Projection...
23 people viewed this question
jasbo
jasbo
