Question about kawasaki Garden
Wildcat w 26 hp Kawasaki eng. turn the key on it goes to HOT on the gauge immediately . I did an engine swap from another mower and used all external parts from original engine. What could this be ?
    Master:
  • 456 Answers
Or wires back to front on the gauge
Posted on Apr 23, 2015
    Sergeant:
  • 462 Answers
Bad ground be first guess
  • 33 Answers
SOURCE: 18hp kawasaki FH531V engine on ride on mower slows down
check the air filter and the fuel filter
Posted on Jan 07, 2009
  • 21 Answers
SOURCE: Swisher will not start with key.
try changing the soloniod
Posted on Jul 28, 2009
  • 33 Answers
SOURCE: My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Posted on Apr 05, 2010
  • 146 Answers
SOURCE: Engine runs fine til hot.
I think one of the intake valves, or a valve pushrod, is bent or warped. When the engine heats up, the metal expands and the valve starts sticking open. That would cause compression to be lost in one cylinder, reducing available power so things drag when you engage the blades. This would also causes air/fuel to be blown back through the intake. I think you'll need to take it to a small engine mechanic. Good luck! Please rate my solution if helpful, thanks.
Posted on Jul 12, 2010
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
Blown Kawasaki engine on a Husqvarna YT48XLS lawn tractor -- only 50 hours?
return it and demand your money back and go to better business bureau
Jun 04, 2015 | Husqvarna Garden
Can I swap the motor from a Husqvarna YTH 180 and put it in a Husqvarna YTH 1848 HP?
The 1848 uses an 18 HP Twin cylinder engine. Mine is a Kawasaki but a similar 18 - 21 HP Kholer will also work. Can't see a problem
Nov 06, 2014 | Husqvarna Garden
I have a 2008 cub cadet rideing mower with a kohler 27 hp ohv v-twin eng. It has 2 coils .eng. model no.sv740s . Coil pt. numbers are 24-584-89s .These coils are about 100.00 dollars ea. Is there a...
it would be odd for both coils to go bad swap coils from side to side see if the misfire goes with the coil if there both died check the kill switch circuit to the coils one of my koher engines also has a ignition module with out a module style and no spark to either cylinder remove the harness side is you get spark with that wire off its a bad safety switch or grounded wire
Aug 09, 2012 | Garden
Need service manual for husqvarna zth6125kaa
Hi and welcome to FixYa, I am Kelly.
You can locate the service manual here for the mower chassis:
http://www.mymowerparts.com/pdf/Husqvarna_Service_Repair_Manuals/W0203003.pdf
For the engine manual I need your engine model number to pass you the repair manual for your Kawasaki or Kohler engine.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
19 hp kawasaki mower motor that dies after operating 45 minutes
well its back to the fule flow,,,i thing the fule lines and carb are blocked up and needs a strip down and a good clean up of all the jets and flote bole this sounds like fule shortage,,,if the engine is only just turning and you try to put it in gear so the cutters start to turn it loads the engine up and it stops!
you say pulling the choke out get it going!!!!! then its short of fule ,,,right!
Jul 15, 2010 | kawasaki Garden
09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Reset change engine oil light
Information taken from: http://www.idavette.net/tech/oilreset.htm
[quote]
The "Change Oil" indicator is reset by using a sequence of Driver Information Center (DIC) key presses as follows:
1. Turn ignition "ON", but do not start engine. (ALDL pin "G" should NOT be grounded.)
2. Press the "ENG/MET" button and release, then, within 5 seconds, press it again.
3. Within 5 seconds of Step 2, press and hold the "GAUGES" button. While the button is held, the "Change Oil" indicator will flash.
4. Continue holding the "GAUGES" button until the "Change Oil" indicator stops flashing and goes out, indicating successful completion of the reset cycle. This should take about 10 seconds.
If it does not successfully reset, turn ignition "OFF" and repeat the procedure from Step 1.
[/quote]
Nov 16, 2009 | 1991 Chevrolet Corvette
Garden Logo
59 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
