Question about Delta T4775 Leland Deck-Mount Bathtub Faucet Trim with Hand Shower T4775. Bathtub Faucets polished chrome. In venetian bronze T4775-RB, brilliance stainless T4775-SS. Leland J-Spout Deck-Mount Roman Tub Faucet Trim with Handshower. 4-hole, 8" - 16" install
I am trying to replace the finial rod that attaches to the diverter assembly.
The knob on the rod came loose and Delta sent me a replacement part. The problem is that the original plumber inserted the rod backwards and I can't get it to unscrew from the diverter assembly. I have tried to remove the spout but despite removing the set screw the spout will not remove with the rod still attached. When I try to unscrew the rod it just turns and turns. How do I remove it if I can't get to the diverter?
4 Suggested Answers
SOURCE: Delta spout diverter broken cannot find direct replacement
I have a Linksys router WRT54G and i was used it on my verizon network, now i want to re-install it to another computer that i have with comcast network
The router was works well with the cable old attached, either the new one, but when I go to wireless it doesn't works
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help. So i want to know what i might suppose to do?
Any help would be apreciated.
Posted on Mar 18, 2010
jeff_drakesr
  • 155 Answers
SOURCE: Removing bath drain
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Posted on Apr 09, 2010
  • 129 Answers
SOURCE: i am trying to replace
yes most are screwed on (ritey titey lefty loosey) if you can send a pic that would be the next best thing to knowing the model # since you probably don't have a pair of channel locks (pliars) w/rubber jaws just use a wash cloth or something and carefully remove the ring hope this helps:)
Posted on Jul 28, 2011
My mother in laws house was built in 1978 and she bought it in 1984. the shower/faucet in the front bathroom is still from the original install. The shower faucet is a Delta scald guard. The faucet still...
Not a problem .your terminology is fine and you are right The diverter assemble screws out and you replace just that part. As long as you can get the nut loose you should be in business. You don't have a very thick area to get a hold of so use a deep sccket if you can.
You should be able to get repair parts fairly easily but you may have to go to a plumbing supply . Good luck and thank you.
Jan 19, 2011 | Delta Home
I have a delta tub shower faucet with a pull-out diverter. The model is "Delex" by Delta as stamped on the cover plates. I have not had any luck finding a replacement diverter. Neither Delta U.S...
take the details to a plumber supply shop ( where the tradies get their parts ) and discuss the problem with them
it is very possible that there are other makes that will fit in the holes to replace the delta unit
Mar 25, 2017 | Delta & Single Handle Shower Faucet
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the...
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Oct 03, 2010 | Delta Faucet Delta RP17453 Pull-Down...
My steering is really sloppy, how do I tighten it up? 1985 olds delta 88.
Check the center link on the steering assembly which the left and right inner tie rods attach to
It may need a replacement. Check all other steering related items as well for wear and looseness
May 31, 2010 | 1985 Oldsmobile Delta 88
I need to replace the push button diverter valve
Take off the knob (screw on bottom of knob)
Take off the face plate (two screws usually hidden by knob)
If you can get a crescent wrench on the diverter's hex shaped part, carefully put the wrench on just the diverter valve portion-it's like a quarter inch wide. righty tighty, lefty loosey. If it doesn't turn, hit it with WD 40, blaster, liquid wrench,etc. and let that soak in. If it still won't turn, call a plumber because you don't want to brute force it-copper pipes bend and break really easily. Don't let your life become a Lucy skit for the price of an hour of plumber.
If it spun and came out, take it to the plumbing store and find the replacement part. There are only two; one chrome, one bronze, as far as I know from my bathroom adventures. Get some teflon tape as well.
Take the matching new one, wrap the threads with a wrap of teflon tape, and carefully thread it in where the old one went by hand until you can't turn it more. Then go another turn or two with the crescent wrench being delicate, not like big angry gorilla. Test it before you replace the knob and face plate to see if it leaks-you don't want it piddling behind your wall. If it works and doesn't piddle, replace the faceplate and then the knob and take a shower.
Nov 14, 2009 | Cars & Trucks
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Delta diverted spout is stuck! Can't pull it down
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
Apr 03, 2009 | Delta Faucet #RP320 Divert Assembly
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta T4775 Leland Deck-Mount Bathtub Faucet Trim with Hand Shower T4775. Bathtub Faucets polished chrome. In venetian bronze T4775-RB, brilliance stainless T4775-SS. Leland J-Spout Deck-Mount Roman Tub Faucet Trim with Handshower. 4-hole, 8" - 16" install Logo
160 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
