Question about Kitchen Appliances - Others
Wiring schematic I need the wiring schematic for the gcg 1580 trash compactor
5 Suggested Answers
SOURCE: Trash Compactor Removal
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Posted on Aug 19, 2008
SOURCE: Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Posted on Dec 25, 2009
burdfrenzy
  • 348 Answers
SOURCE: I have a GE trash compactor I have to hold up the
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Posted on Dec 23, 2010
jcameo7270
  • 675 Answers
SOURCE: Does 15" trash compactor need
If the current rating on the name plate is 15A or better, I would have it on it's own breaker
Posted on Dec 27, 2010
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
I want to install a vinotemp Model: VT-TC32SB. Currently, there is a trash compactor in the space. If I pull the trash compactor out, can I just slide the fridge in place? The countertop and cabinets are...
Hi, It depends a little bit on how your trash compactor and cabinetry are currently set up. Some people have a tough time getting the trash compactor out/cooler in because of the lip that comes down off their counter. However, if you can pull one out, you "should" be able to just slide the other one in. Likewise, you'll need to be sure there is an electrical outlet available in the space. Usually, this isn't a problem as your new Vinotemp will plug right in where the trash compactor was plugged in. But in very old houses sometimes the trash compactor was wired right into the electrical. As long as your counter/cabinets were designed with enough room to move units in/out, this change should go smoothly for you. Best of luck!
Aug 30, 2011 | Refrigerators
Dec 27, 2010 | KitchenAid P Series Trash Compactor -...
HIT FOOT SWITCH AND MOTOR RUNS AND CUTS OFF WITHOUT COMPLETE CYCLE
trouble in ur wire going to the swtich contact ge about this problem looking forward to helping u Shaun
Aug 18, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Jul 13, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Kitchen Appliances - Others Logo
684 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
