Question about Hayward Pool Products ColorLogic Light 12V 50 Ft Cord w/ Stainless Steel Face Ring
Light did work now flashes red. Check voltage reads 13volts. Less than 3 years old.
Can I use a Sunpak MG-1 (10+ yrs. old) with a Pentax K-5 II
The voltage across the points when fired is very high on old style flashguns if you try this on a modern digital camera you may fry the electrics in the camera. Get a flash gun that is compatible with your camera Have look at the Yongnuo range.
Feb 21, 2015 | Pentax Cameras
Vivitar 3200 flash with Canon EOS Rebel T3
it will work with your rebel t3 just set the flash on manual mode and adjust the desired flash power needed .
Jan 16, 2012 | Canon Rebel Cameras
3 red light flashing on power button
Thats the Red Rings of Death; contact Microsoft for a replacement; they will ship you a box to send them; and your replacement should be ready in a week or two.
Mar 09, 2011 | Microsoft Xbox 360 Console
An oranger light flashes then it beeps and turns red and switches off
Orange light flashes can be fix by yourself. Read this blog post you can learn more :
PS3 Red Light Error Fix
Mar 06, 2011 | Sony Playstation 3 (PS3) Console
Three red light flashing around the power button. wont let the controller log in.
I think the controller is the least of your problems...
You have a defective Xbox. Go to the Xbox 360 support page to determine the cause of your problem and to see if Microsoft will repair it for you.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Just follow the on screen instructions.
Feb 22, 2011 | Microsoft Xbox 360 Console
Red light will not stop flashing only just started, less than a year old
When the tool is level, the lasers will stop flashing, but check out the batteries too, because if they're weak, the tool will not level, and the lights will continue to flash .
Dec 20, 2010 | Robotoolz 3 - Beam Level and Plumb Laser,...
Bought a 360 arcade in December and it wont read alot of new games. We think it is burning the disk instead of reading them. It also was showing a red ring of death two weeks after our purchase. We bought...
Because the Xbox is new (less that a year old) Microsoft will repair this problem for free whether the red ring has 1,2 or 3 flashing red lights.
You will also need to tell them about the laser not reading properly.
They will no doubt send you a replacement Xbox as they are well aware of these issues and have even extended their warranty to 3 years with the 3 light red ring of death.
You may however have to wait something in the region of 6 weeks for the Xbox to be returned.
If you need anymore advice please post back.
Regards.
Jul 19, 2010 | Microsoft Xbox 360 Console
I have 1 red light flashing the 3rd one error
You have a general hardware failure, if your console is less than 3 years old and has not been tampered with:ie the case has not been opened you are covered by microsofts 3 year warranty, visit www.xbox.com/support to book a repair free of charge.
If this does not apply there are plenty of guides on this site or on youtube, if you want to tackle this yourself.
Remember thumbs up if this helps.
Feb 06, 2010 | Microsoft Xbox 360 Console
Battery Light
The most likely problem is your alternator, but you can check with a volt meter to ensure that is your problem. Start your truck (use a battery charger or jump to start it if you need to) and put your meter on the battery post's. If your reading 13volts or so your alternator is working and maintaing voltage, however if your reading starts dropping to 10 or less(may take a few moments to drop) then it's probably your alternator. You can also check your battery's voltage before starting your vechile, if the voltage increases after you start the vechile then it seem to be charging. Alternators can be repalced somewhat easily, it's only two bolts however you do have to remove the fan belt, and re-route after installing the new alternator. If you have some expirence working on cars you can do this yourself in your driveway.
Hope this helps
Jun 27, 2008 | 1999 Ford Expedition
My battery light came on while driving. In the manual it is short and sweet...says could be charging device problem. Battery is less that six months old. What is the range of possible problems
Here's a start for you, hope this helps
Jun 26, 2008 | 1997 Chevrolet C2500
Hayward Pool Products ColorLogic Light 12V 50 Ft Cord w/ Stainless Steel Face Ring Logo
471 people viewed this question
Top Hayward Pool Products Electrical Supplies Experts
Steve
Gene Haynes
Are you a Hayward Pool Products Electrical Supply Expert? Answer questions, earn points and help others
