Can I hook the wash and rinse to cold water hose?
  • tom cassidy
    tom cassidy Apr 16, 2015
    Hi linda kay, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Washing Mach... Master
  • 473 Answers
Not sure what you are asking. If you want to wash and rinse you clothes in cold water only, there should be a water temp selection switch to allow you to do that. If you are asking if you can hook cold water hose to both ports on the washer back the answer is yes but it is easier to just cap off the hot side of the water valve on the back of the machine. Most machine water inlet valves are a 3/4 thread garden hose connection. Go to a hardware store or a Lowes/ Homedepot and ask for a screw on cap. They come in both plastic and brass. If you do cap the hot side of the inlet valve, make sure your washer has a cold only setting for wash and rinse and keep it set there. If it gets moved to hot nothing will fill or run.
Posted on Apr 16, 2015
jsrock516
  • 5911 Answers
SOURCE: GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Posted on Apr 29, 2007
SOURCE: Hot water rinse when cold rinse is selected
I am having the same problem - and this is going to cost us a fortune!! How do I switch the wires? We are not sure if it is filling with cold..but when the wash cycle is finished - the clothes come out giving off steam!!!
Posted on Mar 13, 2008
zaids
  • 456 Answers
SOURCE: cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Posted on Apr 12, 2008
BNewberry
  • 93 Answers
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Posted on Jan 12, 2009
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
Moved, now water temp is wrong on cycle. Hoses hooked up as should be. select cold wash it uses hot, and select hot its cold. Problem is when it rinses, it rinses in "cold" which is hot in my case.
many diy people do not connect the house taps up to a standard ( cold for rh tap and hot for lh tap)
the simple solution for you is , the machine doesn't know which tap is which but simply activates the solenoid as required by the program, to simply swap the hoses to the opposite taps
Mar 05, 2017 | Washing Machines
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
Rinse cycle does no work
Be certain that water is on and flowing to BOTH inlet valves. A common problem is the hoses get hooked up backwards, DAD gets a big hot water bill, turns off the hot water (which is connected to the cold water inlet) and the rinse is cold water, so no water, so the machine just stops and waits, forever.... You can often hear a buzzing of the water valve....
Mar 15, 2011 | Roper Washing Machines
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Aug 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front load kenmore washer will not fill on rinse cycle
yes you should have both hot and cold hooked up. if that is not possible splice the line you have and y it into both inlets. thats not the best way to do it but will solve the imediate problem.
Jan 24, 2010 | Kenmore Elite 45986 Front Load Washer
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cold water valve not working
Sounds like either the water valve is bad, or the screen in the valve is clogged. Take the hose (cold) off at the valve and look for the screen to be clogged. If it is not clogged, replace the water inlet valve.
Jan 20, 2010 | Washing Machines
My whrlpool frnt load washer is using hot water in evry setting
Did you check to see if the hot and cold are hooked up backwards? Try switching them.
Apr 20, 2009 | LG WM-2277HW Front Load Washer
Water Temperature is hot on all rinse cycles Water temperature on rinse on all modes is HOT.  Water is hooked up correctly (the delivery folks hooked it up when installing).  Steaming hot - too hot to...
if your gettig hot water on rinse.your fill hoses are not correct.rinse is only cold.switch the hoses.if that dosent solve the problem call for warrenty
Jan 03, 2009 | EuroTech EWF150 Front Load Washer
Water fills to wash, but trickles when rinses
you can try cleaning the filter at hose end, where it hooks into the unit.make sure your cold awater supply is good.
Apr 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
