What Name is power windows under - Computers & Internet
  • Muhammad Irshad Hussain
    Hi Cathy , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How to find wireless network name?
Check the wireless router is set to broadcast the ssid .If it is not you will not see the name of the Wireless Network. It should be listed unless the wireless router has gotten hung up try down powering the router for about 10 seconds and power it up again. Check if Windows 8 is in Aeroplane mode.
http://www.7tutorials.com/how-connect-wireless-networks-windows-8
http://www.7tutorials.com/how-connect-hidden-wireless-networks-windows-8
I am listing the above as Windows 8 if not straight forward in a lot of its settings
Sep 01, 2014 | Computers & Internet
Power windows and radio just quit working?
they should be under the dash but sometimes it can be a different name or more then one thing is run by same fuse escpecially on a newer vehicle
May 26, 2013 | 2002 Ford Explorer
How to re install firewall for windows xp
Click Start/Control Panel/Administrative Tools then click Services. Put your mouse pointer between the columnar headings of Name and Description until it turns into a + then hold the left mouse button and drag the to the right so you can read the entries under the name.
Scroll down under the name column and find "Windows Firewall/Internet Connections Sharing (ICS) and double click on it. When the window opens under the General tab the Startup Type should be set to Automatic, if not change it to Automatic and click Apply, then OK.
May 08, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Non of my windows will mgo down where are the window relays
Hello i can assist you.Your window relays a re located under your hood compartment in the relay fuse cluster.You will need to look closely at the cluster relay name and location diagram if not displayed on the cluster cover you might have to refer to the owners manual for specs and diagram.However i recommend testing your fuse for your power windows located in side the cab of the truck.It was my pleasure assisting you in locating your window relay.John
Dec 31, 2010 | 2006 Dodge Ram
I want to install hp deskjet 3325 in windows 7 ultimate, I have driver CD which works on win xp, how to install the driver for hp printer on win 7?
Follow these steps to install the compatible driver in Windows 7.
  • Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  • From the Windows taskbar, click the Windows icon ( ), and then click Devices and Printers . The Devices and Printers window opens.
  • Click Add a printer . The Add Printer window opens.
  • Click Add a local printer .
  • Click Use an existing port .
  • Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  • Under Manufacturer in the Install the printer driver window, click HP .
  • Under Printers , select the appropriate alternate driver for the product (listed in the table in the previous step), and then click Next .
  • In the Printer name text box, type the product name and then click Next . The print driver starts the installation process.
  • NOTE: The name of the alternate driver displays in the window as the default name. If you prefer, you can change the name of your product. This step is optional.
  • When the installation is complete, a message displays on the computer stating that the product was added successfully.
  • In the message window, click Finished .
  • Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  • Click Close (X ) to close the window.
Nov 04, 2010 | Computers & Internet
Printer not printing.
Follow these steps to resolve the issue. Windows XP
  1. On the Windows taskbar, click Start, and then click All Programs.
  2. Click Accessories, and then click System Tools.
  3. Click Scheduled Tasks. The Scheduled Tasks window opens.
  4. Under Name, click and delete any task that starts with Webreg (for example, Webreg 20031218075500).
  5. Close the Scheduled Tasks window.
Windows Vista
  1. On the Windows taskbar, click the Windows icon (c01319360.gif).
  2. Right-click Computer, and then click Manage. The Computer Management window opens.
  3. In the left pane, click the arrow next to Task Scheduler, and then click Task Scheduler Library.
  4. Under Name, find and click any task that starts with Webreg (for example, Webreg 20031218075500).
  5. In the Actions pane, click Delete.
  6. In the Confirm delete dialog box, click Yes.
  7. Close the Computer Management window.
Windows 7
  6. In the Task Scheduler dialog box, click Yes.
Jul 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
When printer is networked, not found by Windows
Is the printer "Shared"? is DHCP OFF on all the clients? Do they all have a name, password, and be in same workgroup/domain? Check those.
Feb 27, 2010 | Brother MFC-6890CDW Printer
Want to change server name
This is for Windows servers.
Right click "My Computer"
Click on "Properties"
When the "system properties" window opens, click on the tab: Computer Name
Under this tab you will see a button "Change". Click on this and change the server name (you may have to map new network drives for the end users)
This will require a reboot so you may want to do this after hours.
Oct 13, 2009 | Computers & Internet
Forgot power on password
Unfortunatley, you have to reinstall your software from a boot CD if you cannot remember your password. During the Reinstall of windows, it will sometimes ask you if you want to save the documents you currently have in the my documents folder under a different name, depending on which type of windows you are reinstalling. Also, passwords can be Case Sensitive so try that as well.
May 09, 2009 | HP Compaq nx6110 Notebook
Virus
Disconnect your internet, locate the virus name and stop the processes linked to it. Then run a windows search for it and delete all the hits under that name. Then search for the same name in the registry and delete all the matches it finds. Reboot your computer then reconnect to the internet.
Sep 14, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
