Switches ON with green light showing - light goes out after 2 minutes.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inter lock
Posted on Apr 16, 2015
Wiring diagram for 220 volt light with switch
ok here goes first what do you want to do? replace switch or what, all 220 volt lights have a switch, plug has 2 hots( one red-one black), then you have a white and a green, red and black are power, white is neutral and green is ground.whit goes all the way through to light, so does the green, switch controls power so red on one side of switch and black to other side, hopes this helps
Oct 15, 2011 | Home
Where are the wires in my leviton switch I just bought?
There are no wires on the switch. There are 2 screws. The hot wire goes under 1 screw and the switch leg goes under the other screw. The green wire , or ground wire goes to the green screw. If you don't have a ground wire in the box just forget about the green screw.
Jan 16, 2011 | Leviton 15a 120v Sp Switch
I would like to use the 1301 switch but my house circuit has 2 black wires and 1 red wire which terminals do I connect the wires to on the switch?
I don't know the copper-brand 1301 switch
Internet photos of the 1301 show that it has two screw terminals, and a green ground screw
Switch with 2 screws is a single-pole switch. (plug green ground screw)
Sounds like you are replacing 3-way switch with 3 screws. (plus green ground screw)
3-way switches control hallway lights, with switch at each end of hallway.
I think you need to buy a 3-way switch.
How to wire 3-way switch:
Bare ground always goes to green screw
The key is the dark-colored screw.
Old switch has dark-colored screw >> mark this wire.
Attach this wire to dark-colored screw on new switch.
Other two wires go to either screw.
Nov 19, 2010 | Cooper Wiring Devices "COOPER WIRING"...
I have set the run time on my salt water pump and then locked it back to pushing the buttons it shows the time but there are no green lights showing. Did I forget to do something?
one the run time is set you have 2 options
wiat 2-10 minutes for the system to lock itself and for the second green light to come on this mean you are generating
The other method is to lock it yourself do this by once your hours appear for run time then press and hold down arrow again till beep then press and hold up arrow till beep the hour will stop flashing and in 2-10 minutes your second green light will come on
Jun 12, 2010 | Intex Automatic Salt Water System for ...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Usually the red light is on to indacate the batteries are being charged,now the green is the only light that is on
The green light on the charger usually indicates that the batteries are fully charged and you are ready to go. Does the controller show the batteries are fully charged? Can you operate the power wheel chair for several hours? If so, you are good to go.
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced.
Dec 20, 2009 | NRS Hoveround MPV 5 - Used Power...
Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
Aug 02, 2009 | Solis Crema SL-70 Espresso Machine
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Washing Machines Logo
Top Washing Machines Experts
