Question about Hammer Walkrunner Rpe Treadmill
Have moved house and lost magnet, can i get another?
I tried to fix the pull start on my chainsaw since it became stuck. I removed the 4 large screws that hold the housing. Then while attempting to remove the small screw (not realizing it was spring...
A big magnet on a 36 inch string is best for finding the exact screw that flew loose. I use a dial indicator magnetic base and a piece of binder twine. On my first pass around the yard I got five pounds of stuff lost from all the way back to WWII ! Just be patient and swing it back and forth as you move forward and contact all the carport edges and dust around your work area. You will be getting about five dollars of galvanized roofing nails and other things that you can use too.
Jun 02, 2011 | Poulan 18" Wild Thing Chainsaw
MY SIGMA 1009 COMPUTER SCREEN SHOWS 0 MPH WHILE RIDING.SEEMS AS THOUGH IT IS NOT TRANSMITTING ANY INFO. SOMEDAYS IT WORKS PERFECTLY.
You want to make sure the magnet on the front wheel is being picked by the receiver on the fork. Sometimes that magnet attached to the spoke will move on the spoke so that it no longer closely passes by the receiver. If the magnet has been lost, check with you can check with your local bike shop for an extra.
Feb 26, 2011 | Sigma Sport BC 1009 STS Wireless Computer
I have a GBC Shredmaster 2260X. The light on top is blinking that means that the cabinet front foor is not shut. When the front door is shut. I have tried everything I can think of. And it wont work...
most GBX shredders have a magnetic "reed" type switch inside the shredder head that is actuated by a magnet on your door. have you recently lost the magnetic catch on your door? if you have lost it and have access to a strong magnet, you should be able to open door and move magnet around on front side of shredder head and see the light go out. if magnetic catch is on door, then perhaps your door is misaligned in such a way as to not energize the switch.
good luck,
razors
Jan 10, 2011 | Quartet gbc Shredmaster 2260X...
Makita 6935FD has lost all torque. The drill varies speeds when not under load, but won't drive a screw. The battery is charged. If I get the trigger in just the right place the drill will hammer once,...
Remove the brush caps and have a look at the brush length.
If they are extremely short, or barely touching the commutator bars on the armature, you will need to purchase a brush set part # (193466-2). The way you are describing it behaving without a load, and charged battery, I can only assume this will fix it. The other thing you can do is open the clamshell housing and with a pick, attempt to move the armature fan and see if it will make several full rotations. I want to know if a piece of the magnet ring broke loose and is rolling around between the armature and the magnet ring causing your varying RPM.
Nov 20, 2010 | Makita Drills
Pondmaster mdl 24 Series magnetic pump. re: Replacement impeller/magnetic shaft installation Question: What do I need to do to install the impeller ***'y into the pump housing to ALLIGN THE...
The bearing needs to be pressed onto the ceramic shaft before inserting the impeller into the housing. Then it just drops in (while trying to hold on to it the best you can to keep it from slamming in.). New bearings didn't come with the new impeller? If not you will have to carefully pry out the old bearing from inside the housing.
Aug 18, 2010 | Pondmaster Impeller & Magnet for Pond -...
Resistance level does not change anymore. What is
I fixed a problem with my Schwinn Elliptical 430 resistance level not working. When I would change the level anywhere from 1-16, I could hear the motor turning, but there was no change in resistance. If you hear the motor moving, then try this:
Using a Phillips screwdriver, remove all the screws on the left side of the large plastic cover (left side if you are standing on the machine). When all screws are removed, you can pull the plastic cover off, and move it towards the back of the machine without having to disconnect any of the metal bars. (The bottom two screws are a little tricky to get off. Hold the housing in place, don't let it sag, in order to get them out.
Look inside the unit and find the magnet, which is a rounded, brake-show like piece that is close to the flywheel, on the top half of the unit. There's a cable from the motor that goes upward and is attached to the magnet housing.
If you try to adjust the resistance level now, you should see cable move up. This is supposed to allow the magnet to move closer to the flywheel and increase resistance. In my case, the magnet was stuck and wouldn't move upwards. When I gave the magnet a little push with a screwdriver, it popped up to where it should be.
To solve this issue, you will need two wrenches. You must go to the opposite end of the magnet, towards the front of the machine, and you will see it's connected with a nut & bolt. Using a couple wrenches, hold the bolt, and loosen the nut about 1/4 turn.
This should lessen the pressure on the magnet housing and allow it to move freely and not bind. Reassemble everything. Lie the elliptical down on it's side to allow the screws to fall into the holes easier.
Once it's all back together, you should find that the resistance level works again!
Sep 23, 2009 | Schwinn 430 Elliptical Trainer
95' mustang no fire
This also happened to my '95 mustang 5.0L I was actually driving when it lost power. Take the cap off of the distributor and see if the shaft wiggles. The distributor shaft in the mustangs are the weakest point of the engine. If the shaft wobbles the rotor will wobble hitting the points and may break the rotor. All the metal grinding will put little metal shavings in the housing where the magnetic pick-up will attract them, this is the problem. You can replace the magnetic pick-up but if the shaft is moving around you will need a new distributor all around.
Apr 14, 2009 | 1995 Ford Mustang
Presto Model 0692001
Same her but I found this info,
Presto multi cooker magnetic cord 09984
Replacement magnetic cord fits Presto Kitchen Kettle multi cookers from model numbers 0600001, 0600002, 0600003, 0600004, 0600007, 0600009, 0600010, 0600101, 0600110, 0600203, 0600305, 0600306, 0600308. Original part number 09984.look on the bottom of the fryer not on the plug to find these numbers.
Nov 13, 2007 | GE 168997 Deep Fryer
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Hammer Walkrunner Rpe Treadmill Logo
48 people viewed this question
Top Hammer Exercise & Fitness Experts
Debbie
richie46
Electro Med Services...
Are you a Hammer Exercise and Fitnes Expert? Answer questions, earn points and help others
