Question about Garden
Correct tyre pressures for jonsered garden tractor 42inch cut
    Sergeant:
  • 462 Answers
Should say on tire or in manual
Posted on Apr 23, 2015
4 Suggested Answers
  • 40 Answers
SOURCE: Craftsman garden tractor quits when brake released.
Sorry Dunnnutt, but the throttle cable is quite far away from the brake pedal mechanism. Try this Buckijoe: The brake pedal has a switch (look under the tractor) which avoids cranking the engine unless the pedal is fully depressed. A defective switch and related cabling might ground the ignition thus killing the engine when you release the pedal.
Posted on Nov 01, 2009
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
BAMOUT
  • 2478 Answers
SOURCE: stuck pressure release valve on craftsman garden tractor
Adjust your valves. Be sure go 1" past TDC.
Posted on Aug 16, 2012
What is the correct tyre pressure for
NICE TRACTOR!
Tires
Front Dimensions15x6-6 turf
Air Pressure 110-138 kPa (16-20 psi)
Rear Dimensions26 x 12-12 turf
Air Pressure 96.5-110 kPa (14-16 psi)
Here is a link to the manual - very useful!:
http://manuals.deere.com/cceomview/omtcu29065_j0/Output/Index.html?tM=
Jan 03, 2015 | John Deere Garden
Is there anyway to raise the mower deck beyond the 4" height? It really is only 3" and I would like to get it to 5" cutting height. Mower is craftsman zts6000
Inflate the tyres higher, they are normally flotation tyres so will increase the hight with higher pressure
Oct 20, 2013 | Garden
I have 15.5 hp 42 inch cut riding mower when i turn the key all i can hear is a clicking sound
have you tried to jump start it with your car?if so check your safety switches
Apr 26, 2012 | Craftsman Garden
Cuts lower on side
first and foremost! make sure the tire pressure is correct in ALL TIRES and then level the deck.
May 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have an 18hp 42inch cut Sears Craftsman, it will
You might want to checked your fuel line coming from the tank,sometime it will collaspe inside the line and not allow enough gas to get to the engine.
May 15, 2010 | Garden
Cutting grass on even
If the deck is level maybe its the wheels, check your tyre pressure. Stephen.
May 06, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do I make the blades cut level to the ground. They are tipping to one side at present Trish Isopenko p_isopenko@hotmail.com
Check that the tyre pressures are equal (10psi is good) as this can make a big difference. Without knowing you machine make and model I can't help much more than this!
Sep 15, 2009 | Garden
Hi What are the raer tyre pressures for a
Generally around 10 psi. Definately no more than 15 psi. The most important thing is that it is the same pressure in each, or the cut height will be uneven.
Sep 08, 2009 | Mtd Garden
My 42inch cut Yard machines drive belt slips off when I let off the clutch in reverse
check to make sure the belt hold down bracket is under the belt something is causing it to push the belt up when going in reverse
Jul 08, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
