Question about Sanyo DP52848 52 LCD TV
This TV will not turn on. It went out during a storm but the other appliances plugged into the surge protector were ok. I have tried plugging it into other outlets- still nothing
    Top Expert:
  • Sanyo Master
  • 75,404 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 15, 2015
    Top Expert:
  • Sanyo Master
  • 10,875 Answers
There is a fuse inside the back of the tv,set tv on table face down unscrew all screws,pull back off,find fuse replace with the SAME TYPE FUSE.replace back and screws and plug in,put tv on its own surge protector with nothing else plugged in
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
My sharp LC-46SV50U wont turn on
get the service manual and then open it up and do a voltage check on the 5v standby.
if it's not showing anything, then you need to hunt down if it's the ic, cap, or diode or a combination thereof.
Nov 24, 2013 | Sharp LC46SV50U - Lc46sv50u 46in Lcd Ccfl...
How do i stop lightning from getting in my hdmi lines and shocking my tv? 5 tvs went down in one storm
I would recommend getting a surge protector and using that to protect your televisions. This usually will stop something the lightning from killing your tv's.. I have a surge protector and can still use my tv, computer, anything I have plugged in during a storm.
Oct 22, 2012 | Vizio 42 in. LCD TV
Wall ac in off position plug in surge protector blows instantly
It may be possible the it has fried the surge protected internally causing it to short out or blow when plugging in. I would try using another surge protected if you have one or if possible replace the cord going to the unit with a new one and see what happens. Also possible that the outlet your using went bad during the storm as well. Don't know 100% but should be a couple tips to help get you going.
Aug 19, 2012 | Video Game Consoles & Games
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
We had lighnting storm pass by and our TV was plugged into a surge protector along with many other devices. When the storm passed the TV will not turn on anymore.
Likely, the surge protector failed.
Depending on the manufacturer, you may have some sort of warranty available. That is, the manufacturer of the surge protector may reimburse you for the cost of TV repairs.
But foremost, try plugging the TV directly into the wall. It could be that the socket or surge protector were fried, but your TV is ok.
May 06, 2011 | Insignia Televison & Video
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Computer power won't turn on
First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
Jul 20, 2008 | Computers & Internet
Sanyo DP52848 52 LCD TV Logo
70 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
