Question about Electrical Supplies
Troy bilt generator no compression - Electrical Supplies
  • 4088 Answers
SOURCE: I have a Troy Bilt 7800 portable generator. It produces no power.
Make sure the generator/alternator is being driven by the engine. Couplers fail often enough to consider the possibility.
Posted on Sep 14, 2009
  • 4088 Answers
SOURCE: troy bilt gas portable generator not producing
First thing to check is to see if the generator is actually turning--couplers sometimes fail. You need some electrical skills and a voltmeter to trace down problems in the generator beyond checking the health of the two brushes that supply current (< 115 volts DC) into the rotor field circuit. You can find wiring and schematic drawings on the Troy-Built web site, just look for the 030248 model. Another person that I worked with had a similar unit with the same problem. It looked like the voltage regulator board was the problem, but haven't heard back if he had fixed it.
Posted on Sep 26, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
  • 151 Answers
SOURCE: Troy-Bilt 5550 generator. After starting if I move
improper setting in the fuel needles of the carb. what size is the engine? brand?
Posted on Dec 24, 2009
witserv
  • 144 Answers
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
Troy bilt tb490bc trimmer cranks with start fluid but wont run
if it runs on starting fluid but dies after that runs out then you have a carburetor issue not supplying fuel to keep it running
Sep 25, 2013 | Troy-Bilt Garden
Troy-bilt extenda panel xp 7000 generator paney will not display
My Troy-Bilt XP generator doesn't work it runs but it doesn't seem to be put out any electricity. It's new what could the probelm be
Jul 22, 2012 | Briggs & Stratton 20-Amp Extenda Panel -...
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Aug 31, 2011 | Troy-Bilt Garden
I need a manuel or starting instructions for a 8000 Watt Troy Bilt generator.( Model number 65157/30247. This is an electirc or manuel start.
See this webpage for manual:
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/030247-0/Troy-Bilt%20Portable%20Generator%20Operators%20Manual/030247_0esCw/
Feb 19, 2011 | Garden
How do we get a troy-bilt operators manual for a snowthrower model #31AH63N2711
need a replacement manual for a troy bilt generator 5500 watts
Dec 26, 2009 | Garden
Troy bilt gas portable generator not producing
Sep 26, 2009 | Electrical Supplies
Sep 14, 2009 | Electrical Supplies
Jun 20, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
