Where can I order this? And what is the appropriate name for it?
  • Frank  Fernandez
    Frank Fernandez May 16, 2015
    Hi Christopher punzo, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Can you provide a link to a higher resolution picture? I am finding it difficult to see what you are trying to highlight.
    Thanks,
    Frank
Can't open files downloaded from a website get message can't open file
Either file corrupt or you don't have an appropriate software/program to open/access your downloaded files
Can you provide/supply more details as regards the files or you'd have to blindly search for a program that can open the files for you
Another option is to type "file name +plus software" into the search bar of any browser for a list of programs that you can download and install and launch in order to get your files opened
Oct 12, 2017 | Computers & Internet
Unable to sign up my Google account always tell me name unavaible and when I download always says unable to open file pls help
Your google account name is your google email address. It it is indeed yours, then it should work with an appropriate password.
As for downloaded files, you need to ensure that you have an appropriate program to use them. PDF files require a PDF reading application, and so do other programs.
Apr 20, 2015 | Tablets & eReaders
What is DNS?
Hi
DNS stands for Domain Name System and it the system that translates numeric IP addresses to user-friendly Internet addresses.
By itself it shouldn't interfere with Chrome unless the settings for your Internet connection are not finding an appropriate DNS server to do the translation when you ask to access a website.
Hope this helps,
Cheers
Aug 27, 2014 | Google Chrome
Help I bought a onn universal remote and it will not let me put in input to select audio or video
Try to set up it with an other code to your device with this remote control. Check all the codes stated in the code list, and choose one which give you maximum functionality. Never expect a universal remote control will function to all the buttons marked, as it meant for. Choose a code which give you the access to functions you want to. Forget the others. The set-up procedure is a trial and error method; and sometimes it might take a long time to find an appropriate code which gives you the maximum functionality.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Televison & Video
Change boot cd rom bios
There are different methods for BIOS'es, but.........
Boot Order:
1) This method has it where you use the appropriate key (Down Arrow key?), and highlight the boot device you want, in the list.
Then you press the Enter key.
From there you use the appropriate Change value key, and move the boot device to the top of the Boot Order list.
(Page Up/Page Down, or +/- keys)
Then you press the Enter key again, and you are back to the main Boot Order menu.
Now press the appropriate key (Example - F6), and Save Changes.
Or there is a Y/N, or Yes/No to highlight, and then press the Enter key.
You MUST Save Changes, or it will be like you have done NOTHING at all.
2) This style has it where you highlight Boot Order, and then use the appropriate Change Value key, to move the boot order around.
For example you press the Change Value key, and after pressing enough times, the boot device you want will be at the top of the list.
The press the Enter key, and go through the procedure of Saving Changes.
The navigation guide is at the Bottom of each BIOS menu screen.
Does not state navigation guide, though.
Individual navigation comments are to the right side, for each submenu in Boot Order.
Read carefully, and see how to properly set HDD 0 / IDE 0, as the first boot device.
Regards,
joecoolvette
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
My coby 828 mp3 won't list the songs or artists in alphabetical order, how can i get them in alphabetical order?
I don't know your mp3 player specifically, but it's a common issue with the cheaper players that they only display music in alphabetical order of the filename; and to make matters worse, the filename used is the "8.3 filename" (see wikipedia) rather than the long filename.
To establish if this is the case with your player, get a small selection of tracks and name them 001, 002, etc. (preserve the extension, whatever it is), copy them to the player and see if they play in the order of the numbers.
If you find that this technique works to allow you to control the order of play, you will want a more convenient way to manage a larger number of songs. I suggest using a free program called "MRename" by rajko (google for "rajko mrename"). Install this program.
1. To simplify things, copy the songs you want to a special folder for the purpose, because you're going to mess with the filenames.
2. Select all the songs, right click, and choose "MRename --recursion:OFF".
3. Use a select mask of *1 which will select all of them.
4. Use a rename mask of \N301.mp3 (replace 'mp3' if appropriate). This creates names of "N"umbers, "3" digits, with leading "0"s, starting from "1", and adds ".mp3" at the end as a literal.
5. At this point, you can actually move your tracks around in the renaming program... this is where you choose your play order! When you're happy, click "rename all" and it will be done.
6. Copy the tracks to the player, ensuring that they're the only ones on there, and they should play in the order you wanted.
Jan 18, 2011 | Vacuums
I am trying to change the names in the company directory when someone calls after hours or all lines are busy. I cannot find anything in the user manual for the Panasonic KX-T7422 or the KX-TVA50 Voice...
The directory can be in two places. One is the Panasonic automatic directory that is reached by dialing #1. It is taken from the subscriber recording their name in mailbox setup.
The index is found by you entering the first 4 letters of the person's first and last name. It then plays the name from the appropriate mailbox. That's modified in mailbox 999 the system Administrator's box.
The second directory, is one that you establish as part of a custom calling menu. If it is there, it's probably one of the first 5 custom service menus, as the box assigns them in ascending order from 1.
The "user manual" is a publication for the TVA installation and it is comprised of several manuals. Try my website http://www.public.carl.airpost.net/Pana/TVA/
The 330_TVA manual has both the Message and System Manager's instructions.
Carl
Aug 30, 2010 | Panasonic Lands Phones
How can i change my name for chatting
Hi , Follow the procedure: 1.Sign in to Yahoo! messenger using your user ID and password. 2.Press the "Messenger" tab on the page. 3.Click onto the "My Profiles" tab. 4.Hit the "Create/Edit" tab on the page. 5.Scroll through the list of your Yahoo! Messenger ID and any alias names which you've created. On this page you can add or delete names and aliases by simply clicking on the appropriate tab. 6.Set the appropriate display name to "Default." Once you've decided which name you want to be displayed on Yahoo! Messenger, make sure you set that as your "Default" name. 7.Click "Apply" followed by "OK" on the following prompts and you will have successfully changed your display name in Yahoo! Messenger.
Regards, polysandy
Mar 25, 2010 | Yahoo Messenger
I have no cd installer
What hardware are you trying to install?
The appropriate manufacturer's web-site can be a good resource.
For example, if you have HP hardware, access http://support.hp.com and search for "device drivers" for your specific HP hardware.
If you've lost/misplaced the CD/DVD set needed to reinstall Windows, and you have a "brand-name" PC (Dell, eMachines, HP, IBM) you should telephone their Technical Support, and order a replacement set of CD/DVD disks to match the Operating System that was installed when they shipped the computer to you.
Feb 28, 2010 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
