Question about Sewing Machines
Rapid continuous beeping when switched on
Nothing comes up in the display, no error codes or anything. All it does is this rapid continuous beeping. To me means there is a fault with the machines electronics. Has anyone any ideas?
  • Sewing Machines Master
  • 1,860 Answers
Try these suggestions
change needle
rethread machine--top and bobbin--use every thread guide
clean under needle plate and in the bobbin area for lint or loose threads
yes, it can be the electronics of the machine
Posted on Jun 03, 2015
4 Suggested Answers
  • 9 Answers
SOURCE: Error code
Error Code 15 means the presser foot needs to be lifted up.
Posted on Mar 22, 2009
bargainbox
  • 1388 Answers
SOURCE: Error message #1
E1 message means "Fail to initialise stepping motor for zig zag" Either something has jammed the mechanism (broken needle, thread etc) or the stepping motor has failed....if you cannot find obstruction easily, then this is one to send to the Janome service centre for assessment and repair
Posted on Aug 27, 2009
SOURCE: F2 error on brother sewing machine..what does it
On mine this means the button for reverse is stuck. Just wiggle the button a bit and it will pop out again. It can get pushed in at a slight angle and catch a bit, but nothing is broken... I don't know if this is the only thing F2 means, but it is one thing!
Posted on Mar 26, 2010
How do I reset my machine. I have Singer 7285q Patchwork. I got a E7 code, and now my machine will not do anything but beep. Help!
Search for:
Make Model error E7
sometimes the owner's manual shows error codes in the troubleshooting section.
Jun 30, 2017 | Singer Sewing Machines
I turned it on and the display reads 5P and just beeps when I try to do anything. My manual doesn't list this code.
Unable to assist without knowing the make & model of the machine. Error Code 5P varies depending on different make & model.
Nov 01, 2015 | Sewing Machines
No digital display on the screen and will not sew...was sewing along very nicely, changed thread and now have this problem?
It may be something you can fix if you can find a dealer who will tell you what the code means and how to re-set it. The backward and forward C are not a normal code. Does your book have a section for error codes under "trouble shooting?"
Dec 30, 2014 | Singer Sewing Machines
After 3-4 stitches, machine shuts down. On display panel E6 show up.
Error codes are on page 62 of this manual.
It says " The motor locked up because the thread is tangled.
Remove the tangled thread before continuing operetion."
I would guess that this could happen for anything that would cause too much load on the motor.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CE_5000PRW_EN_1444.PDF
Sep 24, 2014 | Sewing Machines
E2 error code brother sewing machine
A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Note Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operationOne beep is sounded.
  • If an incorrect operation is performedTwo or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangledThe sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing
Jan 11, 2014 | Sewing Machines
Code E8 on NS30LE how to fix this
An "E8" message appears on the panel.
Description: You tried to select a different stitch while the twin needle sewing setting was selected (the key is lit).
Select an appropriate stitch, or use the single needle sewing.
    Be sure to check for the cause of the error, and correct it before continuing to sew
Jan 09, 2014 | Brother Sewing Machines
My start/stop switch will not begin sewing
Is the problem with embroidery only? If with both sewing and embroidery function and there is no error code (just 00) on the display, my wife experienced the same problem. There was an internal sensor that was bad. The sewing machine shop repaired with a new Singer part. Part was about $20, labor was $180.
Dec 23, 2008 | Singer CE-200 Quantum Futura Computerized...
Wont Start (brand new) Just Beeps!
make sure the bobbin winder is not engaged and thread the machine over ,also check that the buttonhole switch is not down
Aug 18, 2008 | Singer 7442 Mechanical Sewing Machine
Feed dog & beeping
To make the feed dogs come up ... turn your wheel about 2 times all the way and they will come up (this is after you switch the feed dog switch to the up position)
Jul 14, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
