Question about Canon CLC 1180 Copier
Canon CLC 1180 errors after installing new developers
I'm having problems with my Canon printer. After installing new developers I have made 2-3 successful prints. After that, copy operation is interrupted with error E020/0380. INIT of any color interrupts with errors E020/0124, 0224, 0324 ... Do you have any advice how to fix these errors and start using printer.
    Top Expert:
  • Canon Master
  • 11,573 Answers
Canon 1180 Copier errors
Posted on Aug 09, 2016
maklean
  • 1665 Answers
SOURCE: CLC 1180 with error E020 with sub 124
Hi A service manual below may be helpful.
http://www.nodevice.com/manual/newmans/canon_clc_1180zip/get9816.html
First, check for broken gears or missing teeth on all the developers. That is usually the cause.
E020 is a toner feed problem to the developer
If the copier is still under warranty. It's better to call up Canon 1-800-828-4040 and have them send out a Certified Technician to fix it.
Posted on Jan 29, 2008
Cogz
  • 1326 Answers
SOURCE: CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Posted on Feb 05, 2008
geemarie
  • 876 Answers
SOURCE: error says color ink not installed.
If you attempt to print and the orange light flashes 4 times that means the print cartridge is installed incorrectly. If it flashes 5 times that means there is a probalem with the print head-for example: check the little wire holders comparing to the other cartidge slot. Check the print head for dried ink and clean. Be sure that you are remembering to remove the contact tape that is on a new cartridge.
If you can not solve with this info go here and study the FAQ and the support offered by the manufacturer on your specific model.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
I hope this helps.
Posted on Aug 06, 2008
  • 168 Answers
SOURCE: canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Posted on Dec 29, 2008
  • 67 Answers
SOURCE: E020-00A3
your back up data is currupt, you need to change your p-sens-p value check your door spect for all default value. after that clean your sensors that is found below the black developing assy. take machine off unplug from outlet replug turn machine on DO A GRADUATION ADJUST that should solve the problem / if not unplug the the same sensors , then repeat the first prod.
Posted on Jan 10, 2009
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Solution for canon 1180 clc error code E021 0401
Most Probably Your Black Color Developing asssembly is overloded with excess black toner and might not be rotating. Check it
Oct 15, 2011 | Canon CLC 1180 Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
rotate.
• The developing assembly is not
locked.
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
deteriorated.
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
E020 Error in CLC 1180 Copier
you have a drum/developer related error
Sep 24, 2009 | Canon CLC 1180 Copier
E020-00A3
Dec 24, 2008 | Canon CLC 1180 Copier
Jan 29, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1180 Copier / Digital Colour Printer Print Spreads
hi im jules_09 service manual are not given to clients because its a secret company keeps only there service enginer can avail to it.but if the colore spreads out check your developer or the entrance of each developer somtimes it the developer leak out specially if the developer seal is deffective
Oct 03, 2007 | Canon CLC 1120 Color Copier
Canon CLC 1180 Copier Logo
177 people viewed this question
old marine
old marine
