What does this mean.The drivers for this device are not installed (Code 28)
    Top Expert:
  • 10,875 Answers
You have to go the the company that the device was made by and find the drivers for the item and download them,if you cant figure it out,contact them
Posted on Apr 15, 2015
SOURCE: windows code 28 in philips gogear
o instalato xp nel mio acer e non si sente piu audio cosa devo fare
Posted on Feb 15, 2009
  • 6 Answers
SOURCE: The drivers for this device are not installed.
Depending on what device you are using... google the driver and install it... also windows prefer to install the driver before you install the device... remove the device, install the driver and install the device again. Make sure you uninstall any driver that you tried to install before. May need to restart computer during install and uninstall...
Posted on Jul 18, 2009
  • 37 Answers
SOURCE: driver won't download intellinet ethernet driver os 98
Try to manualy specify the path to your driver using driver update.
Posted on Oct 06, 2009
paul7of9
  • 1189 Answers
SOURCE: pci modem device driver are not installed code 28
  • Hi, go to the Control Panel, select Hardware and Sound. Open the Modem category, click on the Driver button in the Modem Properties window, and "Update" the drivers. If the Drivers in the (Rollback Driver is not Grayed-out, click on the "Rollback Driver" If the "update' do not work! Restart the computer after making all changes. "If the solution helped? Rating it is appreciated, thanks"
Posted on Feb 28, 2010
tagmonkey2k
  • 117 Answers
Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
More info and resolution to this error code can be found here
Posted on Sep 27, 2010
Because I can not connec to internet via the ethernet cable (code 28)?
Go to the Control Panel>Device Manager>Network and find the adapter installed in your unit. Right-Click on the device, go to Properties and note if the drivers are installed...if not, install them
Jul 21, 2012 | Sony VAIO VPCEE31FX Notebook
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
Code 28 can not be install on my pc
error code 28, means a Driver Error,
the solution is to go to the device manager,
1.) start, control panel, system, hardware, device manager,
2.) locate a device with a yellow highlight
3.) right click it and select update , follow the onscreen instructions
or
reinstall the driver using the driver cd. that came with it.
if that fails you need to go to the manufactures website for that particular device , locate the driver and download it, then install it. PS if its on the mainboard you can go to the OEM system builder you have like dell or hp , if you dont have and oem system go to the mainboad manufactures web site, Biostar and MSI.
Mar 31, 2011 | Microsoft Windows XP Professional
Mar 01, 2011 | HP Computers & Internet
Hello, my wireless is not showing on my computer and when i go on device manager on my computer it has a question mark on ethernet controller and say erro code 28, how can i fix this?
Do your Wireless Device (PCI or USB unit) comes with an installation CD? If so, use the CD to install the software/drivers.(Instead of using the Windows wizard). Remove any previous installation before reinstalling with the CD.
Resit your device to a different USB port or PCI slot. If the drivers/software are properly installed, windows will detect and installed the device correctly.
Cause of the Code 28 Error (In general)
A Code 28 error is caused by a missing driver for that particular piece of hardware. There are several of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
1.Restart your computer if you haven't done so already.
2.Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
•Remove or reconfigure the newly installed device.
•Roll back the driver to the version prior to your update.
•Use System Restore to undo recent Device Manager changes.
3.Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
Important: Make sure you install the drivers for the correct operating system. Example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Most Code 28 errors are caused by updating or install the wrong drivers for a device.
4.Update your OS to latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
**Note: Certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
5.Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. Not recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Hope it helps.
Aug 22, 2010 | Microsoft Windows XP Professional
My HD Audio Device does not work. There is a sign "Code 28" and figures 65535 DEvice: ITE IT8716 T-S
This may mean you have incorrect drivers... this sounds like realtek sound.... Code 28 is driver not installed.... If you are sure you have the correct drivers for this hardware than delete and reinstall them but I would make absolutely sure what you are trying to install matches your hardware.
Hope this helps.
Jul 28, 2009 | Computers & Internet
Code 28 not installed
Meaning that the device drivers for your device(s) have not yet been installed. Do you know what that specific device is?
To install the drivers for this device, on the Drivers tab, click Update Driver. This starts the Hardware Update wizard.
If this step will not work, try to locate the CD that came with your device.
Apr 16, 2009 | Computers & Internet
Code 28
Hi
I'm not sure that you can download code 28. This code means that the device drivers are not properly installed or not installed at all. Your best solution would be to download an updated driver for your audio device.
Contact your manufactures webiste and download the latest driver.
Aslo see this link
http://technet.microsoft.com/en-us/library/cc731268(WS.10).aspx
Keep moving forward
Feb 24, 2009 | Microsoft Windows XP Professional
Code 28 drivers
how do i fix code 28 for free
Apr 14, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
