Question about GMC 2004 Yukon XL 1500 Denali
Left signal on my 04 yukon denali causes both left and right to flash at trailer harness and feedback into brack controller.
4 Suggested Answers
duane_wong
  • 6826 Answers
SOURCE: My turn signals don't work.
Maybe there's a crossed wire somewhere because there should be a separate flasher for the turn signals vs. the hazard lights.
Also, the multifunction switch if it has one may be bad for the hazard lights and the turn signal combination somehow. I'm not sure, because I've never heard of this particular problem before.
The logic must be messed up in the switch or it's the wiring.
Posted on Sep 20, 2010
SOURCE: 2004 yukon denali. what could cause the left rear
i would go get a full alignment, more than likely the rear is out of alignment.
Posted on Feb 21, 2011
  • 397 Answers
SOURCE: Have issues with trailer lights.
Standard wiring colors are as follows:
4-Way
5-Way
6-Way
7-Way
Green
Yellow
Brown
White
Red
Blue
Purple
Right Turn & Brake
Left Turn & Brake
Tail Lights
Ground
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
Posted on Jun 26, 2011
Have no power for running lights at trailer plug
The T PARK fuse in the rear fuse-relay block supplies battery positive voltage to a separate park lamp circuit connected to the trailer wiring harness..
For trailer wiring, separate turn signal circuits are connected through the GMSF to the trailer wiring harness.
Fuse Block - Rear
Beneath the left rear seat
Trailer TR/PARK fuse 42 10amp
Apr 14, 2016 | 2007 GMC Envoy Denali
No trailer Brake Lights right or left side
Try the specified fuses in the under hood fuse center. they are common to blow.
Mar 28, 2014 | 2004 GMC Yukon XL
Electrc trailer brake wiring schematic
Not knowing the year or model makes this impossible to answer.
Dec 28, 2013 | RVs
My Yukon denali passenger side door has no power mirror,lock andwindow
ok if the wire is not cut open the small triangle panel on side of dash accessible only with door open. there are you will see the harness plugs for the door. check if they are still locked in and or if they have power to them. (note the right door is controlled by the left door,,, check the harness on the driver side and the switch panel on driver side door for a loose or unplugged harness
Nov 02, 2013 | 2003 GMC Yukon XL
2003 Yukon XL Denali Trailer Light Problems
Lighting control module ? ?????? Hazard / flasher module ! Now ( there''s not even an electrical signal where the fuse plugs into the interior fuse panel.) What FUSE ??????
Stop Lamps
The STOP LP 25 A fuse in the underhood fuse block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both the STOP 15 A fuse and the CHMSL 10 A fuse in the I/P fuse block, and to the turn signal/hazard module. The turn signal/hazard module then supplies voltage to both of the trailer rear turn/stop lamp supply voltage circuits. The voltage from the CHMSL 10 A fuse is to the center high mounted stop lamp (CHMSL) and the trailer jumper harness. The voltage from the STOP 15 A fuse is to the stop lamps, throttle actuator control (TAC) module, and the cruise control.
Backup Lamps
The backup lamp request signal is sent from the powertrain control module (PCM) to the body control module (BCM) on the Class 2 message system. This signal is based on the park neutral position (PNP) switch signal. The BCM supplies voltage on the backup lamp supply voltage circuit to the backup lamps and to the automatic day/night mirror. Voltage for the courtesy lamp supply voltage circuit and backup lamp supply voltage circuit is from the TBC B fuse in the instrument panel fuse block directly through the BCM to these circuits. A short to ground on either of these circuits will open the fuse. The backup lamps are grounded at G401.
For trailer wiring, a separate backup lamp circuit is connected through the underhood fuse block from the TRLR B/U 10 A fuse to the trailer wiring harness.
Turn Signal/Hazard Lamps
The IGN E 10 A fuse in the underhood fuse block supplies battery positive voltage to the turn signal/hazard switch assembly. The FLASH 25 A fuse in the I/P fuse block supplies battery positive voltage to the turn signal/flasher module and ground is supplied at G200. When the turn signal switch is placed in either the left or right position, a voltage signal is completed from the turn signal switch to the turn sign/flasher module. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the turn sign/flasher module. The turn sign/flasher module then sends an on-off voltage signal through the LT TRLR, RT TRLR, LT TURN or RT TURN 10 A fuses in the I/P fuse block to the appropriate turn signal or to all 4 fuses for hazard operation. The instrument panel cluster (IPC) indicators receive voltage from the LT TURN and RT TURN fuses as well as the DDM/PDM for the mirror turn signals. The DDM/PDM has no function or control of the mirror turn signals other that a pass through connection for the circuits. The audio chime is also activated when the turn signals are on. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators. The front turn signals are grounded at G100. The rear turn signals are grounded at G401. The Mirror turn signals are grounded by the DDM/PDM.
Do you know how to do automotive electrical circuit testing with a test light or volt meter ? How to read an use a wiring diagram to pin point testing points . ( connectors , fuse locations etc... ) How to use a power flow chart ? Here is a site for just such info .
http://www.bbbind.com/free_tsb.html Enter vehicle info . year , make , model an engine size . System click lighting , subsystem exterior lighting . Second diagram shows trailer wiring .
Electric Testing Techniques You Need to Know
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
CHEVROLET 2007 SILVERADO TRAILER LIGHT TROUBLESHOOTING
Apr 07, 2017 | 2003 GMC Yukon Denali
2003 Denali has no right trailer turn signal
LEDs overload the original flasher relay.. replace it
if no better
run a new wire for the right trailer turn signal
and check the earths
Mar 31, 2017 | 2003 GMC Yukon Denali
I'm trying to wire my 89 jeep wrangler to be towed useing it's existing lights.the turn signals both flash when right or left is on? I've tryed it under the dash with no luck now all the way...
If the brake and turn signal are on the same bulb than you can Orin straight wiring. If the brake and turn signal are on different bulbs than you'll need a wiring harness with a converter box. I'm pretty sure the wrangler has the brake and turn signal on the Same bulb so let's start with basic trailer wiring. The green wire on the trailer harness is for the right side turn and brake for the trailer. This wire should be attached to the wire on the vehicle that supplies power to the right turn signal/ brake light. The yellow wire is the left turn signal, brake light on the trailer and should be attached to the wire on the vehicle that supplies power to the left turn signal /brake light. The brown wire is the tail lights on the trailer and should be attached to either the left or right side wire on the vehicle that supplies power to the tail lights. The white wire is grounD and it is vitally important that this wire be attached to the vehicle in a manor that supplies a good ground. Failure to suppy a good ground will result in all kinds of funky problems with the trailerer lighting such as all the lights linking when the tail lights and turn signals are on at the same time. If you have any specific questions I will be more than happy to try and help. Good luck.
Jun 29, 2011 | Jeep Wrangler Cars & Trucks
2004 GMC Yukon Denali XL - left side Headlamp issue
plug may not be completely installed? wire the low and high to each other.
Jan 25, 2009 | 2004 GMC Sierra Denali
LEFT TRAILER TURN SIGNAL DOES NOT WORK
I'd get a 12vdc test light if you don't have one already & start from plug, and keep probing back from there. It may be as simple as a bad connection under truck where joined into harness.
Nov 29, 2008 | 2000 Dodge Ram 1500 Truck
02 tundra elect problemblowing fuses when in reverse/using left signal
Trailer? Am I to assume that you have a trailer harness? If so, that may be where your problem lies. Disconnect the trailer harness and plug everything else back together.
Oct 06, 2008 | 2002 Toyota Tundra
GMC 2004 Yukon XL 1500 Denali Logo
296 people viewed this question
Top GMC Computers & Internet Experts
Alun Cox
Jeff Armer
David Ellis Rhea
Are you a GMC Computer and Internet Expert? Answer questions, earn points and help others
