Question about Garden
Water does not come out with force - Garden
What machine?
Posted on Apr 18, 2015
Why does. My boat sit low in the water when i stop to fish it's. A1989 Cajun. Bass boat??????
physics.
As you go through water at any speed the force of the water flowing/being forced beneath it will cause it to rise in the water. When you are stationary there is no pressure applied to the hull. If your boat carries ballast removing some will mean that it displaces less water and will sit higher in the water when stationary.
Archimededs on water displacement?
http://en.wikipedia.org/wiki/Archimedes%27_principle
Jun 10, 2015 | Boating
My 1970 65 horse Johnson out bored having problems with it running in water but runs good with water hose what could it be
quite possible that your motor needs a water pump. hose flushers force water thru at full pressure where as the pump pushes water only what the pump forces thru
Jul 09, 2014 | Boating
No water output on Task Force 2000 Motor seems
pumps have inlet checkvalves that can be in the closed position that the hose pressure is not good enough for valves to open ther are normally behind hex screw.on pump head
Aug 17, 2013 | Garden
What is a water pump
The water pump is on the front of the engine. It pumps water from the radiator and forces that cooler water into the engine block witch forces the hot water into the radiator. In short it circulates the water so the radiator can keep it cool.
Oct 15, 2012 | 1999 Chrysler 300M
An iron anchor weight 600lb in air. how much force is needed to lift the ancher when it is submerged in sea water? the weight density of iron and sea water are respectively 480 lb/ft3 and 64lb/ft3.
Hi .. The anchor will be bouyed by the amount of sea water that it displaces .. 600#/480#/ft3 = 1.25ft3
1.24ft3 of sea water = 64#/ft3 X 1.25ft3 = 80 # lighter
so the force to lift the anchor from that depth will be 520# ...
but as soon as you move it .. the force will change due to the varying density of the sea water due to the presure of the depth of the water ltself .. same as the density of air varies with altitude ..
so this is a finite answer
Thoughts?
Jun 27, 2010 | Flotec TC2104 0-100PSI Pressure Gauge
Detergent dispenser does not empty after washing
it could be either a leaking water inlet valve or the pump is not emptying all the water from the machine and when it goes in to spin centrafugal force forces water back up the filler pipe
Jan 17, 2010 | Kenmore 44102 Front Load Washer
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Dec 24, 2009 | Washing Machines
Keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Feb 24, 2009 | Keurig Platinum B70 Coffee Maker
Top arm does not turn. leaves white stuff all over dishes.
Without having much information to go on, I would venture to guess there is a problem with the water supply. If the initial water fill level is low, the force of the water coming out of the spray arms is minimal and would never be forceful enough to dissolve the detergent used. When starting a a new cycle and it runs for a few minutes...filling then stopping, open the door and take a good look at the level of the water. If below the heating element, add about 1-2 gallons of water and close the door. Does the sound of the water seem to be more forceful? If so, remove your water supply line going to the dishwsher and look inside the valve itself. See if the screen is blocked. If it is, using a small screwdriver, scrape the screen and then blow it out. Reattach and see if the unit fills with more water this time. If I can help further, I am here....
Waiting to hear from you,
Eric Campion
Feb 18, 2009 | Dishwashers
Saeco Aroma Espresso Machine.....doesn't draw water.
You have to take a bellow pump or similary and fill with water, after that you have to open the steam knob and put force in the water from the bellow pump into the water inlet on the machine.
Hope this will help you, let me know if it works.
/Mirran
Aug 16, 2008 | Saeco Aroma Espresso Machine
Garden Logo
219 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
