How do I change from fractions to decimals - Office Equipment & Supplies
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 592 Answers
Divide the numerator (the top number) by the denominator (the bottom number).
For example, 2/7. On your calculator, enter 2 hit the "/" key and then enter 7 and hit "=".
Good luck.
Paul
Posted on Apr 15, 2015
SOURCE: Changing result display from fractions to decimals
Struggled with this and found answer on about page 19 of the instructions on the Internet. Answer also appear on paper instructions under: "Displaying Calculation Results...etc just under "Note" Trick is you must have calculator in "LineIO" mode For setting MODE see "Calculation Modes & cal. Setup in paper instructions.
Posted on Sep 01, 2007
  • 6 Answers
SOURCE: fractions appear when I divide; not decimals
you can also go press the 'mode' button, and go down until you're at 'Exact/Approx' and choose '3: Approximate'
Posted on Sep 20, 2008
supportthe85
  • 35 Answers
SOURCE: fractions multiplied by fraction to get fraction
In the CATALOG there is a >Frac command that can be used with parentheses to multiply fractions.
(1/2)(1/3)>Frac
1/6
Posted on Nov 25, 2008
SOURCE: When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Posted on Dec 08, 2008
  • 60 Answers
SOURCE: TI-89 decimal to fraction
Here is what you do:
1) Press the Mode button.
2) Scroll down the list that appears until you find "Exact/Approx".
3) Change the setting for "Exact/Approx" to Exact.
4) Press enter to save the settings change.
You have three possible settings for "Exact/Approx":
1) Auto - The calculator will try to determine the best format.
2) Exact - The calculator will always give the answer in fraction form.
3) Approximate - The calculator will always give the answer in decimal form.
Posted on Nov 16, 2009
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
I have the sharp model EL-W535. When I divide not whole numbers for example 9 divided by 5 they come up as fractions instead of decimals and i can change it from fractions to decimals but it's very time...
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Jan 30, 2011 | Sharp ELW535 Calculator
How do i change the answers from fractions to decimals
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Oct 20, 2010 | Sharp ELW535 Calculator
How do you change decimals to fractions on a casio
If you enter an improper fraction or a mixed fraction with the the [a b/c] key it will be displayed as a fraction. This result being displayed you can press the [F-D] key to convert the fraction to decimal. If you do nothing else and you press the [F-D] key again, the original fraction will be restored.
However, it seems that you cannot enter an arbitrary decimal number and convert it to a fraction. The [F-D] key seems to work one way : from a fraction to a decimal number. You will only recover a fraction if the original number was a fraction.
Jan 19, 2010 | Casio FX-9750GPlus Calculator
Problem for Casio FX-260 Calculator Changing fractions to decimals
To force a fraction to be displayed as a decimal number put a decimal mark at the end of the numerator OR the denominator. Fraction/decimal result is always decimal.
Nov 12, 2009 | Casio FX-260 Calculator
pressing the 'a b/c' key toggles between fraction and decimal formats
Sep 05, 2009 | Casio FX-260 Calculator
Changing decimals to fractions
You can always convert a fraction to a decimal. The reverse may not always be possible. Look at the example on the screen capture.
You may be lucky and recover a fraction you have just converted into decimal format, but you cannot just write 0.333333333333 and expect the calculator to convert it to 1/3: The true fraction 1/3 has an infinite number of 3's after the decimal mark.
Jan 06, 2009 | Casio FX-260 Calculator
Hope this Helps
Nov 07, 2008 | Casio fx-300ES Calculator
41 people viewed this question
jasbo
jasbo
