Question about Miscellaneous
Help my Inotech color Tv do not want to turn on it has a Black screen and it make a loud piiiiep sound what can by the problem
    Top Expert:
  • 10,875 Answers
Hdtvs use alot less electricity to run too
Posted on Apr 15, 2015
    New Friend:
  • 35 Answers
Bad transformer.
Flat Screen TVs are inexpensive now.
I would replace the TV. Transformers are not cheap! $65.00 & up!
5 Suggested Answers
  • 3422 Answers
SOURCE: I have a Vizio 50"
HI,
I want you to check the cable box if all the wires are attached properly because sometimes it causes disturbance and vertical lines occur.
Here are few troubleshooting steps you can try:
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If the problem still persists you have to get it repaired the repair can cost anything between $200-300.
Goodluck..
Posted on Feb 25, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA HD50LPW42. Sound so loud it sounds like a jet
You need a replacement color wheel or have yours rebuilt since the RCA color wheels are on nationwide back order. You can get your wheel rebuilt at the following link
http://servicemanuals.vstore.ca/
Posted on Sep 11, 2009
Slinteriors
  • 8617 Answers
SOURCE: have picture, but no color and loud humming sound
the color wheel needs replacement. You can get a replacement color wheel at www.tvrepairworld.com
Posted on Oct 17, 2009
caroldon
  • 17130 Answers
SOURCE: TV made a loud sound and color went green on
You TV had encountered a failure for sure and now there is short inthe system. To confirm on the area of fault it is better to remove the power and check the source of the hum. If it is from the drive disconnect to confirm the component but it can be found out by disconnecting the power circuit line on by one. Listen to the hum but take care not to tamper, seek help if not familiar to probe into the power stages. Good day
Posted on Aug 16, 2010
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
I have a Inotech 21' Color TV have a Black screen and at make a loude piiiiiep sound whan I turn it on what is the probleme.This is the Motherbord in the pictere neet help
This is likely a power board issue in the set. The power board may be faulty and an internal relay or other component is switching off the set to avoid any overheating issues. Check this board if you still want to service it.
Apr 15, 2015 | Miscellaneous
Do you have Inotech color tv schematic diagram model no it-29?
I need 29" inotech crt tv schematic diagram(it -29).I need to replace a burned resistor but can not see the value.It's causing pincushion destortion on picture.
Aug 17, 2014 | Televison & Video
Samsung Big screen mod. HL-P6163W made load pop, then buzzing sound with screen going to black and white. Make buzzing sound and no picture when turned back on?
This set has a problem with the color wheel falling apart, which if one of the segments should fly off while the set was on it may sound like a loud pop, and the buzzing sound could be mechanical in nature with the wheel being off balance. If smoke appeared after the loud pop, then it could be a capacitor blowing in the power or video circuits. This model uses two different types of Color Wheel assemblies, either an L3 or a L6 and it would be listed on a white label on the Light Engines metal frame. Hope your solution is this easy.
Bill
Mar 08, 2011 | Samsung HL-P6163W 61" TV
Samsung HL-P5063W audio is fine, no picture. Initially made a loud buzzing sound, so we replaced the color wheel. No more buzzing sound, audio is fine, but screen is various shades of white. Left TV on for...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Bizzare problem with the color
Sounds like something may be wrong with your cable line might need to have it checked.
Aug 19, 2009 | Sony KV-32FS13 TV
Have a polaroid tv, model 3700 seriel F0600181940001053. WATCHING THE OTHER NITE AND A LOUD SQUEAL CAME ON AND THE PICTURE WENT OUT, TURN IT BACK ON TODAY AND THE SQUEAL IS STILL THERE WITH NO PICTURE..NO...
I have a flat screen polaroid lcd hdtv model 3700, first the sound started to get really loud with a beeeeeeeeep when we turned on and after a while was gone, now it doesnt! we had to put mute and connect the tv to a sorround system to hear it without that crazy noise, and now the colors of the tv are gone too its just black and white when we try to see the dish satelite but if we put a movie on the dvd player colors are perfect we try to conect the ps3 player too but its black and white too. Help what can it be!!!!????
Nov 14, 2008 | Televison & Video
Tv turns itself off
hello. it sound's like you have a picture tube that is shorting out from a something arking in side of your set.!!! eather on the (CTR PIN COUSHION).!!! OR ON THS CHASSIE.!!! THAT WHAT MAKING IT DO THAT.!!! TIME TO GET A NEW SET.!!! HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Aug 11, 2008 | RCA 20F511T TV
Black Screen VERY loud noise
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Oct 14, 2007 | Samsung HLN5065W 50" Rear Projection...
Miscellaneous Logo
41 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
