Question about Boating
On a1983 mercury 150 black max how does front cowling plate come off there are no levers or screws
2 Suggested Answers
DoubleClutch
  • 376 Answers
SOURCE: how to install brake lever
there should be a nut on the bottom of the pivot bolt take it off and unscrew the pivot bolt. There maybe a small washer or shim just remember how it came apart and reinstall the new one.
Posted on Sep 28, 2009
Mercury 150 hp 2 stroke 2003 everything runs fine with idle throttle lever engaged but when you put motor into gear i stalls idle to slow how do you adjust it thanks
If someone changed props this can cause this problem. You need to be careful that any adjustment is made for throttle rod and not for carbs if not an injected engine. You do not want to fool around with air mixture. Some throttle cables use threaded linkage and length of rod is adjustment for rpm. Others use a stop screw or hex head to move the throttle lever away from the housings.
Apr 01, 2017 | Mercury Cars & Trucks
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
Trying to change front pads on 2005 jeep grand cheerakee having hard time getting caliber off its like the pistonsr out to far what to do thanks
Hi Max, Take the largest flat screw driver you have and very carefully place it against the back plate of the pad and lever it back so the piston retracts into the cylinder. Regards John
Mar 31, 2012 | 2005 Jeep Grand Cherokee
How do i replace the lcm on my 2004 grand marquis?
The lcm is just right of the steering wheel column and left of and below the radio. you have to remove a plastic cowling under the steering column that is attached by two plastic push pins on either side of the column. there is an accessory light that needs to be unplugged from the cowling. the cowling slides out and the lcm is exposed. it's a black box a bit bigger than the size of a brick and has three wire harnesses plugged into it. the lcm is held in a metal cage bracket with two hex head screws. After removing the screws, the lcm can be pushed up slightly and out of the cage toward the front of the fire wall. it's easier to detach the harnesses after the lcm is out of the cage.
Nov 26, 2011 | 2004 Mercury Grand Marquis
How do I change the cabin air filter?
In the engine compartment, look for a horizontal cover plate in the very front of the black plastic 'cowl', on the passenger side of the vehicle. It's roughly in front of the passenger side wiper blade.
The cover is approximately 2" x 10", and latches on the right-side, remove that cover and the filter is just lifted out
Jan 26, 2011 | 2005 Mercury Monterey
How to replace a windshield wiper motor
the wiper motor is located under the cowl. (the black plastic piece at the bottom of the windshield, under the wiper arms) remove the wiper arms, remove the cowl, it is held on with aprrox 8 phillips screws. Two of these screws are hidden, Open the door on either side and in the crack between the door and the front fender at the top you will see a screw. HTH
Jun 16, 2010 | 1992 Ford Taurus
Cabin air filter
Tools needed are a Phillips screwdriver. Open the hood. Notice the cover for the cabin filter is on the cowl on the passenger side. Remove the screw form the cover. Remove the cover by pulling toward the front of the vehicle. The filter is now visible. Remove by pushing up on the filter to loosen from housing and then pulling out toward the front of the vehicle.
Replace with clean cabin filter. Replace cover by lining up the notches on either side of the cover plate to the grooves in the filter housing. Replace the screw in the cover plate.
Good luck and hope this helps.
Jun 20, 2009 | 1997 Ford F150 Regular Cab
1992 150hp merc black max and hydraulics won't work, sounds like a sick animal.
On the bottom of the trim/tilt cylinder there is a big white slotted head screw usually located on the right side. Turn that out about 3 turns. Have someone help you manually lift the engine and while it is up tighten that screw back up and it should stay. From there you can check your trim lines and check the Cylinder for leaks. Also check to make sure that there is no water in the system. Once the engine is all the way up just engage the tilt lock and you will be able to do anything that you need to without fear of the engine bleeding back down.
May 23, 2009 | Raymarine St6002 Smartpilot Hydraulic...
Cabin air filter
it;s under the cowl vent panel.
Cowl Top Vent Panel Removal
  1. Remove the windshield wiper pivot arm (17526) . Refer to Section 01-16 for the removal procedure.
  1. Remove the front door weatherstrip (20530) to access the windshield outside side moulding screws.
  1. Remove the five windshield outside side moulding screws and the windshield outside side moulding (03136) .
  1. Pull the windshield outside moulding (03144) from the windshield glass (03100) .
  1. Remove the three Phillips-head screws from the cowl top vent panel (022A68) .
  1. Remove the three plastic screws by turning them 90 degrees to unlock.
  1. Remove the six pushpins from the front edge of the cowl top vent panel .
  1. Lift up on the cowl top vent panel and disconnect the windshield washer hose (17A605) at the Y-connector.
  1. Remove the cowl top vent panel .
Mar 15, 2009 | 1998 Mercury Villager
My vacuum takes off in drive
Some months ago I fell over my K-G6 at nite. Later the handle appeared looser than normal. Gradually, it started having the possessed yank-you-off-your-feet feel. This week I carefully disassembled the chrome plated cowling cover the handle goes thru to look inside. Two top machine screws when the front hood is lifted, two rear screws in the plastic, a single center screw near the drive-neutral toggle and a single screw for the power cord strain relief. I removed the handle by taking the two large screws off. This allowed the cowling to come free. From the rear, on the left side is a lever with a two pronged fork pointing up. The fork is supposed to stick into the receiver mechanism which is part of the handle slide. I get it: as the user pushes and pulls on the handle while vacuuming, the handle assembly slides back and forth and transmits commands thru the mechanical linkage to the drive mechanism. My fork was not engaged in the receiver. The reason was 3 screws on the left side of the brass block assembly were loose and the small black wedge was partially crushed. I dissassembled, cleaned, oiled and replaced the pieces and cinched down the 5 machine screws holding both brass blocks and the wedge. When I did this, I noticed the fork engaged with the receiver. Now reassembled, my Kirby runs pretty good and no longer feels possessed. And yes the roller height does make a difference on the drive assist reaction.
Mar 28, 2007 | Kirby G6 Bagged Upright Vacuum
Boating Logo
80 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
