Question about Crosley Refrigerators
My Crosley Conservator Ice maker will only produce crushed ice, HELP!
How do I fix this problem? It keeps spitting out crushed ice even when the cubed ice button is on.
    Top Expert:
  • Crosley Master
  • 10,875 Answers
Ensure the Wire Signal Arm is not in UP position. • Ice maker should produce 2.5 to 3 pounds of ice in a 24 hour period. • Water supply is turned off. • Water pressure is too low. • The freezer is not cold enough.
Posted on Apr 15, 2015
Testimonial: "the wire signal arm is down. it's producing ice just fine. all of the above is fine. I really am stuck..."
  • 3 more comments
  • Chloe Jochum-Klasel
    Chloe Jochum-Klasel Apr 15, 2015
  •  johnny rebel
    johnny rebel Apr 15, 2015
    then you will need to clean it,use an ice maker cleaner that is non toxic and follow instructions,also change filter
  •  johnny rebel
    http://www.homedepot.com/p/Whirlpool-16-...
    thank you Johnny for your help. fingers crossed I fix the dang thing :)
  •  johnny rebel
    kool
The ice maker of our GE GSH25JSXSS is only producing crushed ice even when it's set to cubed. Is there a way to fix this issue?
Check that the shifter bar on the bottom of the ice bin is moving to shift from cubed ice to crushed. With the ice bin out you should see movement in the back wall of the freezer with the light switch button held in while changing the dispenser controls from cubed to crushed. GSH25JSXASS Parts
Ice Bin Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | GE Refrigerators
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
ICE MAKER
to solve the frozen food problem, turn the temp back to 4. this should be the factory recomended setting. the only dispensing crush ice is probably a bad solinoid. you will find this behind the back wall. it engages to lift the thin metal rod on the bottom of the ice bucket to dispense cubed ice. and the ice being frozen in the bucket is probably a bad ice flapper in the door. it's letting warm moist air into the ice bucket that is freezing
Apr 23, 2010 | GE GSH25JFR Side by Side Refrigerator
Frigidaire model glrs267zcwi side by side. Crushed ice comes out when either the crushed or the cubed button is depressed. How to fix it please?
It sounds like the water line to the ice maker is partially obstructed (probably semi-frozen) and the unit is making smaller than normal ice cubes. This causes the ice ejector to "shatter" the smaller cubes, producing the appearance of crushed ice.
The easiest thing to try is make sure the water line connection inside the freeezer isn't frozen. A hair dryer can be used to thaw the inlet to the ice maker, but just be careful. Remove some of the product in the compartment so you have enough room to work.
Dec 12, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Our brand new 3 door 25' LG has stopped producing ice. The switch is ''on'', and water dispenser works. The motor operates to send either cubes or crushed ice out the dispenser, but NO ICE. What do I look...
LG has problems with there ice makers. if is less than a year old it is under warrenty--even if you dont have a reciept. sounds like the ice maker needs replaced. i have replaced several that were less than a year old.
Oct 28, 2009 | Refrigerators
Ice maker crushes ice will not extrude cube cubes
Your ice bin is out of alignment. Pull the ice bin all the way out and re-insert it and make sure it locks in place. When you re-insert the bin,look underneath the bin. You will see a metal rod. It must go INSIDE the yoke at the rear of the freezer, NOT under the yoke and NOT over the yoke. In the yoke.
This is a common problem and will happen again. The ice bin has a way of dislodging itself. If the rod is not in the correct position you get crushed ice regardless of the setting.
Sep 29, 2009 | Frigidaire Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Ice maker only operates on crushed ice mode
There should be a solenoid behind the ice bucket that moves an metal arm on the ice bucket to move the crush teeth away for cubes or keeps the crush teeth in place for crushed cubes. Bad solenoid, bad wire at the solenoid, broken solenoid/mechanism piece, bent arm, no power from dispenser to the solenoid are -some- possible trouble makers.
Also the solenoid that controls the crush/cube function is probably frozen. First, pull out your ice bucket. On the bottom of the bucket is a long metal rod the runs all the way to the back wall of the freezer. That rod runs into a little square hole in the back of the freezer. The hole is about 1 and half inches square. Just put your finger in there and see if the solenoid plunger moves up and down easily. If it doesn't move, then it is frozen. Just hit that area with a hair dryer and it will release. If it moves easily, then make sure that the the rod on the ice bucket is seated in there properly
Feb 09, 2009 | Kenmore Refrigerators
My fridedaire side-by-side only gives crushed ice even when cube ice button is chosen
take the ice bucket out of the freezer
from the back of the ice bucket, there is a little metal bar that stickes out (back left bottom)
that little metal bar inserts into a hole with a spring loaded 'up/down' mechanism...this is stuck UP, and needs to be jiggled with your finger to spring down.
Once that mechanism inside the hole springs down, the ice maker will go back to producing whole ice cubes.
Oct 04, 2008 | Refrigerators
Refrigerators Logo
103 people viewed this question
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
fta777
ray gallant
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
