Washer lid lock keeps flashing and unable to proceed thru cyckes
  • Washing Mach... Master
  • 2,355 Answers
Replace lid lock switch
Posted on Apr 15, 2015
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
I have a high efficiency washer and I am unable to start my washer because the lid lock keeps flashing and will not lock. What do I do. This wager is not a year old.
Check the door catch see if there is anything stopping closure.if that is okay try resetting the machine.most reset by switching of from the wall socket.then hold the start button in for at least five seconds whilst switching on from the power point.it sounds like the child lock is trying to activate.read the manual to see if you can set this to default.
Jan 24, 2015 | Washing Machines
Why does my lid lock keep flashing?
There is a right lid lock and a left lid lock which did you change? The left lid lock is a lock and the reed switch which tells the machine control the lid is closed and can start the cycle.
May 03, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Aquasmart lid
Is the lid lock tang on lid broken.
2.9 Lid Lock
The Phase 7 Washer uses the same lid lock that is used on
the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
has completed, the lock will release and the lid can be
opened. To open the lid during the cycle the
START/PAUSE button must be pressed, the machine will
come to a halt, and the lid locked LED will extinguish.
If the lid is left open, the machine will be unable to lock the lid
and the cycle will be halted. The machine will play a tune
and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
• If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
lock. Note: This is the only time in which we would recommend doing this.
• If the harness is damaged, the complete lid lock assembly will need to be replaced.
If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
Mar 16, 2013 | Fisher Paykel EcoSmart GWL15
Washing machine won't go thru spin cycle. Lid lock light flashed some at first, now won't come on at all.
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Jul 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
My mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
my mah9700aww door stays locked and when i try to start it in any cycke i just hear a humming coming from the assy pump drain.
Aug 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
The lock light flashes and the machine continues to try and lock even though it appears to be locked...stops filling Maytag neptune TL
Are you up for troubleshooting? I will try to keep it low tech.
Do both Lid locks remain locked (you can't open the lid ) and you just have the Locked LED is flashing?
I'm assuming if you hit the OFF key the machine will unlock is that correct?
If so I feel you have lost signaling thru the lid locks possible do to corrision. We would start on the Left Hand lid lock which would require removal and very carefully opening up the case halves of that lid lock.
Here is a pic of what we might find inside...... some corrision;
Let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Jul 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
MY MAYTAG NEPTUNE MODEL FAV6800AWQ KEEPS DISPLAYING THE LETTERS OP
You have lost signaling thru the Left Hand lid Lock. The washer has not see the lid go closed thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
You could have a Lid Magnet out of position or severe corrosion. You can place a large magnet over the Left bumper like this and see if the OP error code clears;
See this post for troubleshooting the OP error code Left Hand Lid Lock Troubleshooting I go over OD error code troubleshooting but you troubleshoot the issue the same way for the OP error code.
If the Lid Magnet is not out of position you may have an open circuit thru the Magnetic Reed Relay as shown in the Pics of this link Left Hand Lid Lock Troubleshooting.
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference..........Rich
Jun 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Whirpool washer type 111 will not spin
I wouldnt think so, Have you checked the lid switch? If it stops when it get to the spin cycke, you have either a bad lid switch or your missing the piece on the lid that pushes on the switch.
Please rate solution
Sep 07, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
