Question about Home
Lithonia 427G EL replaced ballast with exact replacement. New bulbs (3 bulb fixture) red led light is still on. Do I need to replace PS300 battery pack now. Or just replace fixture with new model?
ctf1800
  • 4402 Answers
SOURCE: Yellow blinking status light
I would make sure you have it seated correctly into the ballest some times the connector will come undun
Posted on Jan 18, 2008
projdoc
  • 2237 Answers
SOURCE: no display from projector
try resetting the lamp timer. if that doesn't work: listen for a high pitched whir when you power it on. if you don't hear it, the colorwheel needs replacing. if you do hear it and it doesn't light, the ballast is bad and needs replacing.
Posted on Aug 10, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Posted on Jan 10, 2010
  • 23 Answers
SOURCE: I replaced the lamp when and the red LED light
More likely a faulty ballast. Check connections.
Posted on Jan 21, 2010
  • 111 Answers
SOURCE: Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Posted on Feb 03, 2010
I have a T12 fluorescent light fixture and replaced the bulbs and ballast. I have double checked all the wiring connections. I get the bulbs to light when I move the bulbs, but only for a second.
Your description sounds like the connectors for the tubes. Also RECHECK wiring. Different on newer ballasts. See below...
Turn off fixture, unplug, or deactivate fuse...
Pull out bulbs and the tin fixture cover/reflector.
Extract the bulb connector. Go to hardware and buy 4 more, and just replace them. The connections fail where the wire connects and the rigours of bulb replacements damage this piece. TONS easier to get new pieces.
ALSO!!!! many new (fancy schmancy) ballasts WIRE UP completely differently from the old ballast. Follow the wiring diagram on the NEW ballast. This detail trips up many.
Doc
Sep 13, 2016 | Photography
I have a building full of 427G lights with 12-15 that won't work, but appear to have good bulbs. What is the issue?
Florecent or the yellow HPS bulbs? If HPS you have a bad bulb, or bad ballast. May be similar issues if florecent.
Mar 05, 2015 | Lithonia Lighting Home
We have Lithonia 2 bulb fixtures in a recessed ceiling. We currently have 2 (25) watt bulbs in them. What wattage can I upgrade to ??
The ballast inside the fixture is rated to operate 2 25w bulbs. You can't put higher wattage bulbs in this fixture, unless you change the ballast. Sorry.
Sep 22, 2014 | Lithonia Lighting Fluorescent Flush Mount...
Fluorescent light only one bulb out of two burning very dim
I like to start by swapping the position of the bulbs. If the one that didn't light, now does, it probably indicates a bad ballast (that long thin black "boxy thing" with wires coming out of it - it may be under a removable metal cover). Next replace the unlit bulb with a new one. If that doesn't light, try swapping the new light to the other position. If you still can't get two bulbs to light, replace both lamps with new ones. A good indication of a bad bulb is one or both blackened ends. The bulbs having two pins on each end have a small filament inside. This blackening is the metal of the filament "boiling off" and depositing on the glass. Eventually the filament gets thin and breaks so it doesn't provide the heat necessary to "prime"" the mercury inside the bulb that conducts electricity and excites the phosphor coating inside the bulb that emits light.If none of this works, most probably the ballast has "gone bad" and it, or the whole fixture, must be replaced, normally by an electrician. This can be done by the home "handyperson." You can cut the wires, remove the old ballast and replace it with a new one, splicing them to those of the same color from the new ballast using small "wire nuts." The one black and one white are the 120 volt power input wires. There are normally a pair of reds, a pair of blues, and a pair of yellows. Any wires of the same color are interchangeable. The blues and reds will go respectively to the bulb's sockets on one end of the fixture; the two yellows go to the opposite fixture end and are connected, in parallel electrically, to the other lamp sockets. If this makes sense, you may attempt to change your own ballast. If not, hire an electrician. Match the specifications for voltage, wattage, and number of bulbs, from your old ballast to the replacement - there are several different important electrical values to match even if the ballast looks physically the same size. Last, always turn off the electricity, and verify that it is safely off using a test light or meter before working on the fixture. Even though the black wire is normally energized and the white has zero volts measured with respect to ground, sometimes their function is reversed by an amateur where the wall switch may disconnect the black wire and make the fixture go off (as it should) yet the white wire remains dangerously energized, which is why you always test both of the wires with the test light or meter with respect to ground before touching any of them. Again, if this is not PERFECTLY clear, hire an electrician. Don't take chances, Electricity KILLS!
Apr 20, 2013 | Home
Replaced sylvania 26 w 4 pin in overhead light fixture and it is not working
replace the ballast almost always these lights do not usually burn out the ballasts go bad
Dec 13, 2012 | Lithonia Lighting Fluorescent Flush Mount...
Have you used the LED lights 12 Volt Led Light Bulbs are high energy saving, energy efficient and are small in size. They offer a brighter light than any incandescent bulb and have a low replacement and...
Hello There,
If you plan to have LED lights in your household the easyest thing is to buy the ones, they are made for line voltage (120 V). You have choices for bulb like shape or tubes. The tubes are available for direct replacement (using the existing ballast) ot the line voltage ones (the fixture's wiring should be modified and the ballast needs to be removed). The power saving is constant, by the time passing by you are saving.
Hopefully, this will help you. If you have more specific question, please let me know.
Jul 29, 2017 | Laser Vehicle Parts & Accessories
We have 48" lithonia flouresent
even if there is power at the sockets, ballast may not have power to fire off the lamps, how old is this fixture, and you need to replace the ballast same as in fixture, if you replace ballast make diagram of wiring so you can rewire it like it was wired from store.
Aug 21, 2011 | Lithonia Lighting White Finish 2 12" High...
My 4ft fluorescent fixture has whiye and black wires that have been connected, hot and nuetral but it also has a red (brown) wire ? where does this go.
They make dimmable ballasts.
The Lutron dimming ballast shows an orange wire, not a brown >> but other manufacturers might call for different color.
I am guessing here, but ballast should work with Black Hot and White Neutral
I want you to answer back and say if the ballast works with just white and black, Thank you.
Here is a 3-way dimmer to control florescent ballast
Oct 18, 2010 | Lithonia Lighting Lithonia Ps300...
Jan 19, 2010 | HP VP6111 Multimedia Projector
Kill power to light and emergency single light does not turn on also with power on push test knob and emergency bulb not come on
Hello Ramon, Check the power back (battery cell) as without a functioning battery pack, the emerbency light won't function.
Typically the batery packs will need to be replaced periodically every 4-5 years, depending on the istallation location and ambient temperatures.
When you kill the power to the emergency lighting circuit the PSQ is switched to operate automatically on battery power only. The same thing occurs when you press the test button; it disconnects the lighting from the electric power that keeps the battery charged and ready for service. You might also want to check the bulbs with a test meter (remove the bulbs from the fixture and test with the Ohm setting) While rare that these bulbs burn out, since they aren't usually illuminated often, only during a power disruption/outage, etc.
Here's a link to the Lithonia site with the spec sheets for the PSQ series of emergency lighting products, for your use and reference.
http://www.lithonia.com/product/advSrch.aspx
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | Lithonia Lighting Psq500 Power Sentry...
Home Logo
408 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
