Question about Maytag Dryers
Giving me code f 01 won't start working what to do to fix it is mag tag dryer that won't work
    Top Expert:
  • Maytag Master
  • 44,381 Answers
Kenmore dryer model 11087531701 powers on but will not start. Sends code f-01. What does this code mean? How can we fix this?
The 110.87531701 dryer was manufactured by Whirlpool for the Kenmore label. For Whirlpool dryers, the F-01 code indicates an internal of the main electronic control board (the brain of the dryer). Try unplugging the dryer (or turning it off at the circuit breaker). Wait a while, then plug in the power cord. If the dryer now works, you may have had an electrical surge that needed to be dissipated.
Otherwise, the recommended repair is replacing the control board. Make sure to unplug the dryer before opening the back panel to access the control board. Move one wire at a time from the old board to the same place on the new board. If you have a gentle touch and soldering skills, some have repaired the board by finding the faulty solder joint and fixing it. However, you need to make sure that you remove and replace the wires with care.
See https://www.repairclinic.com/Shop-For-Parts/a8b6d876505/Model-11087531701-Kenmore-Dryer-Parts or http://www.searspartsdirect.com/model-number/11087531701/0582/0151200.html?searchType=modelSearch&q=110.87531701&searchTerm=110.87531701 for a parts list. The control board is part 46 on the cabinet parts diagram at Sears Parts Direct.
I hope this helps.
Jun 29, 2017 | Kenmore Dryers
417.84052500 electric dry 05 model safe mode code. Everything lights up but won't run
Rocky, Could be door switch problem.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bypass dryer door switch Whirlpool
Dryer Not Starting How to Test the Door Switch
. Whirlpool Kenmore Dryer Repair 01 Won Start or Run Door Switch 3406107...
http://www.selfhelpforums.com/archive/index.php/t-10060.html
Mar 13, 2016 | Kenmore Dryers
Dryer has f01 error
F-01 is a failed communication of the=> Whirlpool Dryer Main Control Board W10174745 The control board has likely shorted out. Not a cheap fix but it is a fix
APPLIANCE 911
Nov 28, 2015 | Dryers
Won't work. No service code.
the first things to check is the door switch,open the door and push in the switch,if it doesn\'t click when pushed in the switch is bad,next thing to check is the belt,on some models there\'s a switch on the pulley assy. if there isn\'t any tension on the pulley the dryer won\'t start.if you need more help i need the model number off of the dryer,open the door and lolook around the opening where you put the clothes in and you\'ll see a tag with the model number,if the dryer hasn\'t been taken apart and cleaned out the thermal fuse could have popped,if the dryer gets to hot inside from a blocked vent line or the duct that the lint filter slides into is blocked the fuse will pop and it\'s non resetable.
Mar 18, 2013 | Kenmore Dryers
My toaster showing f5 mag temp and it only toast for 6 seconds then stops any ideas???
assuming its been fixed by now.
thermal-couples on mags trigger at 160F i believe.. forces shutdown for safety.
possible causes..several
mag fan working?
EC fan working?
mag cooling fins packed with dust?
wave guides full of crud causing arching?
mag tip burnt?
faulty mag thermal-couple, unlikely
Nov 07, 2012 | TurboChef TORNADO Electric Oven
Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
Nov 06, 2012 | Dryers
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Dryer f51 error
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Nov 04, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
751 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
