What does "Not available" means on a phaser 3300mfp
3 Suggested Answers
SOURCE: Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
Posted on May 04, 2011
SOURCE: scanner locked on Xerox phaser
There is a green switch on the top of area where paper comes out. That locks the scanner
Posted on May 18, 2011
Xerox IR 3300 Copy Quality Promblem
I believe you might have a Canon Imagerunner 3300, Xerox has a Phaser 3300mfp. Can you confirm the model and what is the quality problem, lines, dots, ghosting, etc.
Jan 14, 2016 | Xerox Office Equipment & Supplies
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
PAPER STICKS TOGETHER
Probably requires separation pad cleaning/replacement
Mar 28, 2014 | Xerox Printer Division Xerox Phaser...
How to check ink levels on xerox phaser 3300mfp
print a configuration page or consumable page/status
Feb 26, 2014 | Xerox Office Equipment & Supplies
Does not print properly
Take out the cartridge and checkout whether its filled or not, if it is filled shake it once or twice and then reinsert it otherwise fill the cartridge ink and then use it.
Apr 18, 2013 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
Scanner locked on Xerox phaser 3300MFP
May 12, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Oscar M
May 06, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Does this model(8200 or 7200) supports OCR feature
yes it does below is the link for your printers manual you can go through it. It tells you how the ocr feature works with your printer.
download.support.xerox.com/pub/docs/3300MFP/.../Guide_EN.pdf
Feb 03, 2010 | Xerox Phaser 8200 Laser Printer
29 people viewed this question
k24674
jasbo
jasbo
