We are unable recieve programmes through the blu-ray player on to the Television, i.e I player and demand
All the programmes are itemised on the Blu-ray.Start up, when I attempt to load a program. I am shown internet content connection status, Then told a new network up date is available. Then I am informed a net work error has occurred. I would appreciate any help to correct this problem Email derekchris@bormes24.fsnet.co.uk
    New Friend:
  • 35 Answers
Some models require a USB "Memory Stick"
to be plugged into them to enable them to upgrade!
Look for a USB port.
Posted on Apr 15, 2015
Adding amazon app to blu-ray player
Unfortunately, no. All the apps that are on any Blu-Ray are added or removed by the manufacturer. In your case, Netflix pays Vizio to put their app on there. I've seen apps removed and added from players during updates. So unless Amazon and Vizio make some sort of an agreement, that player will never be able to access anymore than what was loaded on it when you bought it.
Jan 20, 2014 | Vizio VBR220 Blu-Ray Player
Bd5500 cant load disc
Blu-ray require a higher speed when playing a disc so they can produce the hd picture, making the demands on the motor much greater.
Jul 24, 2012 | Samsung BDC5500 Player
Dynex blu ray player reads dvd not blu rays
If you cannot play the blu-ray disc, it means the laser pickup cannot play with the precision and speed that blu-ray demands, standard DVD put less demands on the system allowing them to play. It is possible a firmware update might be available to resolve this, if not! cheaper to replace the player than changing the laser pickup assembly.
Apr 08, 2012 | Televison & Video
After recording a programme it stops half way through when playing it back this happens occasionally we are unable to carry on with the recorded programme once it stops
Try to play a couple of dvds on another dvd player thru the point yours stopa to see if the recording is bad or the player portion is defective. Also is unit under warranty?
Sep 14, 2011 | Televison & Video
Won't play 1080p discs?
From this problem's description I have to assume that either the blu ray player will not play blu rays or the blu ray player will play blu rays but only in 1080i/720p or that you want to know if this blu ray player supports the 1080p resolution.
If the blu ray player is not playing blu rays then you update the firmware and try multiple purchased discs to make sure nothing is wrong with the ones you have been trying. If blu rays that played once will no longer play, then you will need to reset the blu ray player from its menu and possibly by holding down the power button on the front of the unit until the word reset displays on the unit before trying to play the disc again.
If the television is not showing 1080p make sure you are connected with an hdmi cable and that it is the right version hdmi cable for this blu ray player and for your television. Make sure you have chosen 1080p as the resolution to display in the blu ray player's menu. If all of that has been done and 1080p will still not display then it is a case of incompatibility between manufacturers--Sharp and whatever the television is. It would display in 1080p on a Sharp television and most likely on a Samsung and Sony as well. With other brands and even some models of the aforementioned brands (except for Sharp) its a toss up.
Mar 05, 2011 | Sharp Aquos BDHP50 Blu-Ray Player
My samsung bd-p1500 blu-ray player won't play blu-ray discs on regular ones... was having all sorts of troubles with it finally updated the firmware and now it won't play any blu-ray discs
I'm having the same problem. had my Blu-ray and my cable box plugged into my reciever. Blu-ray kept cutting out and not finding a signal while watching my Rome DVDs. I swapped HDMI cables by just switch which cable went out of my blu-ray ( I didn't change what ports they were plugged into on the reciever. That cleared up that problem. I'd assume it was a faulty HDMI cable except that it works fine on the cable box. Anyways, we were watching Iron Man on Blue-Ray and it starts to skip about 2 thirds through the movie. Same as you I updated the firmware, disabled BC-Live, No luck Don't know if the problem is hte Bluray player , the reciever or what. Everything is up to date so I don't get it at all.
Apr 01, 2010 | Samsung BD-P1500 Blu-Ray Player
My HDMI cable wont work from my new Blu-Ray player
On the blu- ray player you have to set it to HDMI in the options or else it wont work
Oct 24, 2009 | Samsung BD-P4600 Blu-Ray Player
Blu-ray player won't play through hdmi with yamaha reciever
The problem is some intermediate connections do not allow the HDCP signal to reach the telivison. Electronic HDMI switches have this issue. I have one HDMI port on my Telivision and I have a Blu-ray player & HD satellite reciever. I had purchased a two in one electronic switch and found that the satellite reciever signal would make it to the tv and was working but the blu-ray player was not. I had to by a passive push button switch and it allows the HDCP signal thru. The funny thing is the electronic switch was supposed to be HDCP compliant and it still did not work.
Sep 06, 2009 | Yamaha Audio Players & Recorders
MIXED SIGNALS?
I think, titels are changed other wise both are same signals.
Jul 26, 2008 | Toshiba Televison & Video
Sony DVD Recorder not recording correctly
RETURN THIS ITEM UNDER WARANTY,DEMAND A REFUND AND PURCHASE A MORE UP TO DATE MODEL
Oct 23, 2007 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
