Question about Home
How do you change the bulb on this model of puck lighting?
How to change a light bulb on my Frigidaire oven model RT 70 light bulb in the signal light area in the surface unit switch?
Hello Heidi, thanks you for your inquiry!
From the information you have provided you need to change the light bulb inside of your Frigidaire Imperial Electric Range. This appears to be an older model and I was unable to locate any direct information on how to change a bulb. Since your appliance is older than ten years old the manufacturer may not have any information for it. You may need to perform a generic search online for further help with the bulbs or speak with a local technician. I hope this information is helpful. -Matt
Jun 02, 2015 | Frigidaire Kitchen Ranges
CHANGE LIGHT BULB I BATH FAN
According to Broan's site - the model you specified has no light bulb - check specifications - you can search the site for the proper model and download the instructions.
http://www.broan.com/products/product/4108f1af-c993-4327-982f-1174f091fd6f
Apr 12, 2014 | Broan-NuTone Broan 110 CFM Premium Bath...
Light socket failure
You could clean the sockets with WD40. LED bulbs are more reliable. You can get better quality LED Bulbs that give the same light as a normal bulb. You can use higher wattage LED bulbs, but only up to the same level as the light fitting will take. So if the fitting says up to 40 watts, you can get a LED bulb up to the equivalent of 40 watts
Apr 07, 2017 | GE Kitchen Ranges
I need a owners manual for wolfgang puck bristol toaster oven and bottom pizza cooker bdcorp10
Wolfgang Puck Instruction Manual for the BTOBR0040 is available here:
http://www.wpcookware.com/instructions/BTOBR0040.pdf
Other Wolfgang Puck Instruction Manuals are available here:
http://www.wpcookware.com/manuals.asp
If you do not see your model number for your product, suggest you contact their Customer service at 1-800-275-8273 to determine if the Instruction Manual for your model is available. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Feb 06, 2011 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Nee a manual for a wolfgang puck Bistro food processor
Sorry someone has not responded sooner, but just discovered this site.
Jul 20, 2010 | Wolfgang Puck Bistro 620 Food Processor
Need plastic tray replacement for model number BRGG0010/wolfgang puck electric grill.
Replacement parts for the Wolfgang Puck BRGG0010 Grill are available here:
http://www.wpcookware.com/products.asp?cat=80
May 20, 2010 | Wolfgang Puck CCRG0030 Indoor Grill
WOlfgang Puck Deep Fryer 1500 watts power cord
Hi - The 1700 watt fryer uses a magnetic release cord set type TA 35 P. If your unit says "use only with TA HSING CORD SET TYPE TA 35P, It should work.
Oct 22, 2007 | Wolfgang Puck Bistro 1700 Deep Fryer
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
