Question about Samsung Televison & Video
How to fix Samsung LED TV no Picture
Used flashlight can still see shadowy images. when press menu reset picture appears.
  • Samsung Master
  • 681 Answers
The power inverter board is defective. It has to be replaced.
Posted on May 27, 2015
  • 10 Answers
SOURCE: Dell W2300 LCD TV Picture Problem
Your problem is due to intermittent power in the backlighting circuit. This is usually caused by swelling of electrolytic capacitors in the power board. If you can find an honest electronics technician it is about a $40.00 fix.
Posted on Jan 18, 2008
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
dsacco86
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
  • 6 Answers
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
  • 6 Answers
SOURCE: I have sound, but no picture. Screen is black.
Same caps and fuse as other people with backlight problems.
Posted on Jan 04, 2010
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
How to fix a samsung tv
dear my friend if you are electronics technician try to check led back light driver circuit or the back light led inside tv screen .thanks
Oct 03, 2017 | Samsung Televison & Video
Samsung PN64 no picture
hi is this tv led, if so shine a flashlight on the screen see if you can see an image, if you can the led in the panel has shorted, out thanks
shaun
Jun 12, 2017 | Samsung Televison & Video
TV Samsung 50 UN50EH5300FXZA BJ04. Sound but no picture. Replaced all boards, still no picture. Flashlight test saw image.
Hi Rick,
It appears to be a case of backlight failure. since you have replaced all the boards, inverter is ruled out. Some of the LEDs in the backlight array may have gone bad. Fault is repairable, but needs care and experience of opening and repairing the LED panel. Good luck.
Oct 16, 2016 | Samsung Televison & Video
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Samsung led tv no picture
What did you do when you say you cleaned the screen? If you shine a flashlight on the screen can you see some very dim picture? If the back light is out. This will require replacing the power board.
Jan 06, 2014 | Televison & Video
I have a samsung dv3 television. it has started
try this with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on with manufactures menu you will see RESET use ONLY DOWN NAVIGATION until reset is highlighted and PRESS RIGHT NAVIGATION this will reset all tv settings PRESS STANDBY TO EXIT and then re tune all stations
hope this helped
Nov 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Flat panel led is green, no picture
Check if the picture would show the menu once the menu button is pressed on the tv. If it appears you may want to check the source of your signal. Check the cables and try using different port. It may either be a bad cable or a bad port. See if a PS3 or a dvd player would show a picture. If it does, you may want to check the source. Have it checked or use it on another TV to isolate the problem.
Oct 09, 2009 | Televison & Video
Televison & Video Logo
67 people viewed this question
Henry  Thomas
Henry Thomas
