Question about Radio Communications
How do I tune the thing - Radio Communications
  • Robert McClure May 22, 2015
    Hi Peter Hudson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How do I set the tuner to tune at different keys?
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
Mar 06, 2015 | Music
HOW DO I TUNE A KRAMER GUITAR
Without seeing your guitar, I'm going to assume the "tightening lugs" you're reffering to are the string locks on the nut. On a guitar with a "floyd rose" style tremolo system, the strings pass through a clamping system at the nut before going to the normal tuning keys. This clamping system "lugs" must be loosened then the guitar is tuned as it normally would, then the lugs are tightened to lock the strings in place. These clamps are not part of the tuning mechanism, but instead lock down the strings after they have been tuned by the keys. After all that, one would fine tune the guitar at the bridge rather than at the keys. A more complete explaination is found here-
String Tuning Instructions
Feb 17, 2015 | Kramer Music
While I was having my fuel pump replaced it was suggested that I get a tune up the next month I had a tune up now it won't start . Had a bad bank on the coil pack replaced it now no spark ??
No tune-up on your vehicle, only preventative maintenance
Vehicle Computers have been tuning things for the last 30 years
All you got left there is Spark Plugs
Treat all vehicles the same- as for as maintenance goes
Can't tell you a thing without the vehicle to test,you should know that
Sep 16, 2013 | 2001 Ford Explorer Sport
Need key code for tunup utilities
Tune up ? forget it this is a big bug thing you can do it yourself by using --msconfig-- in start /run i wouldnt touch any of these tune up programmes with the proverbial barge pole to be honest
Dec 02, 2011 | Computers & Internet
The parts needed for a tuneup on a 2004 chev aveo
Define tune-up
Spark Plugs --- are all that is left of what was a tune-up 35 years ago
Are you doing preventative maintenance or you have a
drivability problem ?
We just need the symptoms of what the car does
Sep 20, 2011 | 2004 Chevrolet Aveo
I have a 2002 ford zx2 with a little over 100000 miles. I was told the only thing necessary for a tuneup would be new plugs. Is this correct?
In my world your correct
Tune-ups have been gone for 25 years,
as computers do all the tuning
Spark plugs are all that is left & they are
called preventative maintenance, as they
always were.
You can do air filter,gas filter,clean MAF Sensor
etc, but not tuning anything,just restoring things
Jun 23, 2011 | 2002 Ford ZX2
I want to know how much will it cost to get a tune-up?
There is no real tune up any more.
The main thing with a tune up was points, timing, and valve adjustment.
Now all you can do it change the spark plugs and filters.
Mar 04, 2010 | 2004 Honda Accord
I would like to know, what exactly E-Tune stands for and how much power a Subaru Legacy GT twin Turbo has got.
E-Tune smei Tune don't mean a thing but to your horse power question 280 hp out of the box....for the years they where in production
Aug 05, 2008 | 2005 Subaru Legacy
Manually tuning the reciever
you should be able to tune in manually.
press tune
press fm or am
press d. tuning
enter the frequency of the station 4 or 5 digits ie 9370 or 10450
another thing to look into would be getting a yagi fm antenna, they are directional and although you may have to rotate it for best results, they work great.
Nov 20, 2007 | Sony STR-DE985 Receiver
Radio Communications Logo
238 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
