2nd tv bedroom when i connect screen is white with black stadic and it said I have no signal
    Top Expert:
  • Televison & ... Master
  • 43,095 Answers
Well it does have to have a cable or antenna hooked to it and be set to proper input
Posted on Apr 15, 2015
F2 button not working
Fn plus CTRL plus F2 key?
Really.............
I haven't looked yet. Yep, just that lazy.
Most laptops have one single key to press, for the Display Toggle-Over key.
Per se such as hold the Fn key down, and tap once on the F2 key.
Post back in a Comment.
Regards,
joecoolvette
Mar 30, 2013 | MSI Wind U100-030US Laptop
PS3 used to work on TV in bedroom and on TV in lounge, now it won't work on TV in bedroom
I believe your Lounge TV is an HDTV and your Bedroom TV isn't, This is what you have to do:
1. Connect it to
your Lounge TV with an HDMI cable and a red/white/yellow cable.
2. Turn it on and go to the display settings and switch it to the composite cable setting.
3. Change your TV channel where you would see the red/white/yellow cable and accept it that way.
4. You should be all set. Take it to the regular TV and connect it with the red/white/yellow cable.
cheers :)
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
Have purchased new 37" toshiba.
Check the lead from the lounge to the bedroom is connected correctly. The blue screen means no signal.
Jan 01, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I have three tvs in my house all off the same ariel.The tv in lounge ok as is the one in 1st bedroom.In our bedroom keep losing signal, have had a booster fitted recently.
I expect the connections could be in need of attention. Check the point where they are connected via that booster. If you have a portable to test the bedroom and rule out the tuner in the bedroom TV?
Hope that helps.
Dec 29, 2010 | Televison & Video
Sky wired up by a basic splitter in loft want to use red eye.
Your vocabulary is not helping I will make some assumptions.
1 you have an antenna setup and want to have three tvs use it.
2 I don't know what sky is so I am going to ignore it.
from the antenna you will run a short length of rfcoaxial to a splitter\booster witch is powered this will allow you to split the signal to 4 or two or three tvs your choice. all tvs will need coax or rf cable run to them and btw 300 ohm cable is not called rf
coaxial cable is preferred because of its signal insulating properties and its longer life expectancy and all tvs today have coaxial inputs on them not 300 ohm.
Jan 19, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Had working sky remote in bedroom, now no remote sky operation from upstairs, is there a secret installer code to switch this function on?
Have you got a magic eye in the bedroom,if so the little red light should be on,if it is not then you are not getting a signal from the main box.You need to check the 2nd rf output is switched on in the main box.
Nov 02, 2009 | Televison & Video
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
RF module related to Direct TV.
yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
Oct 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Bought a monte carlo ceiling fan. removed old fan and found 3 white and 3 black wires, plus grounds. Cannot figure out how to connect the unit up. breaker controls all ceiling lights in master bath,2nd...
Try this:
* All 3 black together, with black and blue from fan
* All 3 white together, with white from fan
* All grounds (earths) together, with all greens from fan
Apr 28, 2008 | Hampton Bay 24002 Ceiling Fan
BLACK SCREEN WITH SOUND
Is the TV connected to cable? Is there a cable box? Is it connected to a satellite box? How is the signal connecting to the TV - the F connector, the red,white,yellow, red,white,,s-video or component RCA jacks? If you can see the onscreen menu then it usually indicates that the TV is working fine and the problem is with the signal into the TV.
Aug 19, 2007 | Hitachi 60UX58B 60" Rear Projection...
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
Electro Med Services...
