Question about DISH Network 311 DTV Receiver
REPLACING MY 2700 DISH RECEIVER WITH A 311 WILL THIS WORK WITH THE LNBF THAT IS ON THE DISH 500 OR DO I NEED A NEW LNBF.
We have a dish 500 on cabin. We take the 2700 when we go. will the 311 work?
4 Suggested Answers
  • 374 Answers
SOURCE: Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Posted on Sep 04, 2008
  • 374 Answers
SOURCE: dish 311 receiver tv/antenna input part is broken
No the receivers are not serviceable by customers and will void your warranty if you have one. If you own the receiver you might take it to an electronic repair shop. Thanks for using Fix Ya.
Posted on Aug 16, 2009
TommyF DISH
  • 263 Answers
Delivering video anywhere, anytime.
    Verified Fixya Pro
    SOURCE: my dish 311 receiver goes on and off when connected to dish pro plus lnb
    rdjennings10,
    It does sound like there could be a power problem with the receiver. The Dish Pro Plus LNB won't cause any issues with that receiver. If the receiver is plugged into a power strip or surge protector, try plugging it directly into the wall. If it is already directly into the wall, try a different outlet if available.
    If the problem persists, we will have to replace the equipment. You can reach me at thomas.faust@dish.com to get that taken care of.
    Tommy Faust
    DISH Social Media Representative
    Posted on Nov 01, 2012
    Hello- using dish 500 with twin lnbf, 311 receiver. 119 locked in easy with 70 signal . When trying to find 110, I cannot get a strong enough signal to lock. 129 signal shows strong along bottom of point...
    Hi CharlieO my name is Mike of DISH Network and I was reading over your post and seenwhere your 110 satellite is not locking in or on your install summary screen. Iwould be more than happy to help with this issue and to research further I willneed to look at the account to look what satellites they have setup on youraccount. I will need your account number or your phone number; I will leave mye-mail so you can contact me directly. Michael.houston@dishnetwork.com
    Jan 30, 2011 | RCA DISH Network(r) 311 Satellite System
    Getting an error code 311, dish says its the hard drive and i have lost everything help
    Hello! Daniel Busa here with Dish Network's customer service department. If you're getting the 311 message this is most likely an indication your hard drive is bad. Try unplugging it for ten seconds if it persists you may need a replacement. If it does persist I will send a replacement please e-mail me at : daniel.busa@dishnetwork.com
    Jan 04, 2011 | DISH Network 311 DTV Receiver
    Sat finder detects signal on 61.5 Sat but receiver does not display or lock.
    Hi, Mary with Dish Network Customer Service. The 61.5 Satellite carries mostly High Definition programming. If your Satellite Dish is an older model, it is not equipped to bring that Satellite in. It is the part on the Dish called the LNBF (the eyes) that will pick up the satellites. Your receiver is a Standard Definition, you should be reading the 119 & 100 Satellites. I hope this helped but if you have additional questions, please let me know.
    Dec 22, 2010 | DISH Network 311 DTV Receiver
    I changed out a tv and dont know how to program without a recieve
    If you have a 311 receiver or any single/solo receiver than you will need to put the new set on channel 3. If you a have a duo receiver try 60air or 73cable. Thanks for using Fix Ya.
    May 02, 2009 | DISH Network 311 DTV Receiver
    Can the second card over ride the internal card?
    Yes they are able to work with the internal and external smart cards. The internal is not really a card at all and is over ridden by the external device. In order to get the new smartcard to operate you need to follow the instructions that came with it. In some cases you may need to call dish and have them associate the new smartcard with the receiver and have it forced through on their end. Thanks for using Fix Ya.
    Mar 16, 2009 | DISH Network 311 DTV Receiver
    Satellite dish receiver error LNB Drift detected
    that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
    Apr 22, 2008 | DISH Network 301 DTV Receiver
    Dish 500 and receiver 311
    100% yes. that's what it is supposed to be connected to.
    Jan 27, 2008 | RCA DISH Network(r) 311 Satellite System
    Dish network 119
    you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
    Jan 12, 2008 | RCA DISH Network(r) 311 Satellite System
    RCA HDTV, indoor antenna and Dish Receiver 311
    I want to use two (2) 311 dish receivers with only 1 outside antenna.
    Jan 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
    DISH Network 311 DTV Receiver Logo
    113 people viewed this question
    Top DISH Network Televison & Video Experts
    brian soufane
    john milligan
    Jaime Hernandez
    Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
