Question about Home
We have fitted a new ballcok on our cold water tank now we are having trouble with cold water to shower head
keemo68
  • 1263 Answers
SOURCE: hansgrohe shower
it's possible sometimes you can get brand new junk. one question is the thermo coupler in the right postion? i would check to make sure that it is indeed picking up the temp like it should.
Posted on Sep 03, 2008
  • 44 Answers
SOURCE: cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
jonbrown725
  • 73 Answers
SOURCE: Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
lester482529
  • 226 Answers
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
We have fitted a new ballcock on the watertank (cold) since then we have little cold water
Are you sure the ballcock is correctly adjusted to fill the tank to the required level? The float should have a screw on it which changes the height at which the valve is closed. if set too low you may not get enough head of water to feed the system. If set too high the tank will overflow.
This video deals with a toilet (WC) cistern but the principal is the same for any ballcock valve system.
How to adjust the cistern ballcock in your WC cistern get better flush
Apr 15, 2015 | Home
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape.
First and foremost, read the install instructions that come with the new shower head...
After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water.
Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube.
Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench.
You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall.
To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head.
Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently.
Here's a nice short video on the subject, illustrating my instructions: http://youtu.be/fiv4Zq9v4co
Jul 27, 2014 | Delta Faucet Home
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
On OpulenceTM SHOWER Trim Kit w/8incg Sunflower Showerhead, the water presure is too low on both hot & cold, seems like there isn't sufficent water to supply the 8inch head. the model number is 502057BNT....
Either this is a consequence of having a "low-flow" shower head, or the pipes are too small or have too many bends and elbows to support the flow rate required at 65 PSI for such a large shower head. What is the water pressure at the shower head fitting while the shower is running? It won't be 65 PSI, but it shouldn't be below the recommended inlet pressure for the unit.
Feb 26, 2018 | Danze Home
I have a bristan 8.5kw electric shower, temp fluctuated to very hot, then to very cold. Now only cold. I had a combi boiler fitted now the shower seems broken, does this have any relevance to the flu
Changing the heating system will not affect an electric shower as it is run from the cold water supply,sound like the temp thermostat has blown ,contact bristan or there website to get a replacement thermostat,telling them which model electric showrr you have.
Sep 13, 2017 | Home
I am putting in a new shower and want to put in a pump to increase the flow of water to the shower head,what pump do I need? I will put it next to the hot water cylinder in the airing cupboard,I also want...
First of all, the normal water pressure is anywhere from 50 to 70 lbs. Why do you need a pump? What you need is just water pressure. The shower head will only put out a fraction of that pressure with the valve body inside the head. Since you do not say what water pressure you have, check all the pressure lines to make sure there is no blockage. As for the water tank, well, 50 gallons is always better.
Dec 01, 2009 | Cars & Trucks
Problems getting hot water to the shower
If you have good water pressure to every other hot water faucet inj the house then the problem lies in the shower valves. There are some very small passages in the valve and getting dirt removed can be very hard to do. You could try trurning the water off and blowing air back through the shower or taking apart the valve and flushing the valve out with it dissasembled.
But my opinion is that the problem is in the valve.
Nov 12, 2009 | Plumbing
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
Cold water suply filling up header tank in loft thru hot water suply on shower.
Oct 05, 2008 | Home
Home Logo
130 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
