Question about Polaroid Televison & Video
How do I connect a soundbar to my polaroid tv it only has a headphone out .the sound isn't very good
Is there another way to connect my soundbar to my telivision ive got it connected through the headphone socket to the two RCA sockets on the back of the sounbar the sound isnt very good and there's a humming noise . unfortunatley there is only the RCA sockets on the sounbar .Any help would be appreciated .Ive just noticed a coax out and subwoofer out can I use either of these bearing in mind the soundbar only has the RCA sockets .thanks
    Master:
  • Polaroid Master
  • 382 Answers
The coax out is a digital sound output. You can not use that on your soundbar. The sub out is for hooking the tv to a subwoofer (bass only). You gonna have to use the Headphones output, buy a good 3.5mm to rca cable preferably one with a built-in noise filter so it can attenuate the "hum". Also try lower the volume on the TV so you can have less distortion. That's all!
Posted on Jun 03, 2015
  • 1894 Answers
SOURCE: How to connect headphones without a headphone socket
if there is differentiation between the sockets you will need the manual..
Posted on Mar 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: how to connect headphones if the tv doesn't have a headphone jack
Hi!
You can buy a rca to 3.5mm jack adapter from the link---
http://www.amazon.com/gp/offer-listing/B0002KR5Q0/ref=dp_olp_2
And it will help you to use a headphone with your TV.
Thanks
Rylee
Posted on Jan 23, 2009
  • 7 Answers
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Posted on Oct 03, 2008
SOURCE: Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Posted on Dec 27, 2008
  • 4 Answers
SOURCE: HD set top box to PC via HDMI
it should be an HDMI Output, you should be able to hook up to a monitor with no problems but directly to a PC, not so much. In what way will you be using this application, that may help
Posted on Apr 29, 2009
No sound from tv. it says 'paired - not connected' How do I connect? Thanks
You have a soundbar?
And the soundbar is paired?
Next... go to your TV remote control ... navigate into settings... and change the sound setting to external device
Mar 02, 2016 | iHip Audio Players & Recorders
How do I connect my Sanyo DP42D23 TV to my Sanyo FWSB415E soundbar?
I doubt that the instructions say to connect to a headphone connector on the rear of your TV. More likely, the supplied cable connects to some other kind of AUDIO output. It might be identified as EXTERNAL AUDIO or AUDIO OUT.
Jul 18, 2015 | Sanyo 42" 1080p LED-LCD HDTV - DP42D23
How do I get my headphones to work with my Panasonic smart tv and LG soundbar?
Let me see if I can understand what you want to accomplish.
You have a Panasonic Smart TV, and an LG soundbar. But you want to use a set of headphone. I guess that your TV is already connected to the soundbar, no?
The first thing that you need to check is for an output, it must be from the sounbar, it could be a 3.5mm jack, or an RCA jack. Usually soundbars only have input, meaning that only takes the sound in, never out. If you have an audio output from the TV, you c an always try, but the soundbar won't be use then.
Feb 06, 2015 | LG Televison & Video
Has elcd42p3dl10 polaroid tv got an output
If there is no audio out socket at the TV; you can't take out the audio from it; to connect to a sound-bar. Gopakumar Gopalan Google
Jan 03, 2015 | Polaroid Televison & Video
Can beats s450 be connected to any soundbar?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
Sep 27, 2014 | Beats By Dr Dre - Wireless Bluetooth...
Why doesnt my goodmans soundbar work? It is connected to aux on tv and soundbar only makes buzzing sound
The AUX sockets on the TV are for sending a signal in to the TV. This is what's known as an input.
Signals don't come out of any socket that is labeled in or input. If you want signals to come out of a device, then the correct socket to look for is labeled out or output
The cheapest way of connecting your flats screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
Sep 08, 2014 | Televison & Video
LG sound bar don't work on LG tv
Need models of TV and soundbar to be more specific.
Generic help: Not plugged in correctly (you connected to the TVs red and white sockets without realising that they are a "signal in" and not a "signal out" type socket. Incompatible (i.e. a soundbar that uses ARC but the TV doesn't have it). Wrong TV settings - You're connected to the headphone jack but you didn't bother reading the manual that tells you there's a separate control for audio out via that jack and it's buried in the menus. The list goes on.....
Read the manuals, and don't just guess where things plug in. That's always a good start.
Sep 07, 2014 | Televison & Video
How to connect soundbar to a TV with a skybox
Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
Sep 04, 2014 | Televison & Video
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
Televison & Video Logo
110 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
