Question about Home
We have fitted a new ballcock on the watertank (cold) since then we have little cold water
    Master:
  • 369 Answers
Are you sure the ballcock is correctly adjusted to fill the tank to the required level? The float should have a screw on it which changes the height at which the valve is closed. if set too low you may not get enough head of water to feed the system. If set too high the tank will overflow.
This video deals with a toilet (WC) cistern but the principal is the same for any ballcock valve system.
How to adjust the cistern ballcock in your WC cistern get better flush
Posted on Apr 15, 2015
How to adjust bowl water level
Adjust the ballcock float level.. Where the float ball rod attaches to the ballcock there is a little screw on top turn it so the float ball can move up higher and wont shut off to soon
Hope this helps Mike
Jan 30, 2016 | Gerber 28-380 pressure assist toilet...
Tip
HOW TO CHANGE A BALLCOCK ON COMMODE
HOW TO REPLACE A BALLCOCK ON A WATER CLOSET, COMMODE: FIRST SHUT WATER OFF TO COMMODE. THER WILL BE A WATER SHUTOFF VALVE BETWEEN THE FLOOR AND THE COMMODE ON THE WATER LINE TO YOUR BALLCOCK, TURN WATER OFF, FLUSH COMODE SO YOU CAN CLEAR MOST ALL OF THE WATER OUT OF IT. THEN UNCREW THE NUT FOR THE WATER SUPPLY, THEN UNSREW THE NUT FOR THE BALLCOCK ITSELF, OPEN THE TOP OF THE COMMODE, YOU WILL SEE A FLAPPER ON THE BALLCOCK, REMOVE IT, THEN TAKE THE BALLCOCK OUT, SOME HAVE A ROD AND FLOAT SOME DO NOT, EITHER WAY IF IT DOES WHEN YOU PUT THE BALLCOCK BACK IN THE SAME WAY THE OLD ONE CAME OUT MAKE SURE YOU HAVE THE GASKET ON WHEN YOU STICK THE END OF THE BALLCOCK BACK, TIGHTEN THE NUT, THEN MAKE SURE YOUR WASHER IS IN THE NUT ON THE WATER LINE AND RE CIONNECT WATER LINE, YOU CAN ADUST FLOAT VALVE BY BENDING THE ROD DOWN TO THE AMOUNT OF WATER YOU WILL WANT CONNECT FLAPPER BACK, TO THE NEW BALLCOCK, IF THE BALLCOCK DOES NOT HAVE A FLOAT, YOU CAN ADJUST PER INSTRUCTION, SO AFTER ALL THIS IS DONE AND TUBE IS CONNECTED FROM BALLCOCK TO THE TOP OF IT WITH CLIP, TO DIRECT YOUR FILL WATER, TURN YOUR WATER ON AND ADJUST SOME MORE IF NEED BE, UNTILL YOUR CORRECT AMOUNT OF WATER IS LIKE YOU WANT IT...THIS IS REALLY EASY COMPARED TO PAYING A PLUMBER FOR THIS JOB, AND IT HAS TO BE DONE QUITE OFTEN, LARRY VEAL MASTER PLUMBER TEXAS
on Apr 24, 2010 | Plumbing
Can't get system fill message off jura impress z5
My guess would be that your water tank float is trapped.
The remidy would be to descale the watertank itself.
If you use the Calris filter cartridge. remove it before descaling with a mild commercially available descaler. Don't forget to rinse thorrowly afterwards and reinsert the filter. Always use cold water to fill the watertank.
Hope this helps
Oct 05, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
I installed a new ballcock assy and float. the toilet fills and shuts off but i can still hear an intermittant water flow. there were no instructions with the new valve so i dont know how to adjust.this is...
Without knowing what type of ballcock assembly you used I can't tell you how to adjust it. However there is one easy thing that you can check. If you have a plastic line going from the ballcock to fill/overflow in tank make sure that the bottom of that line is not below the water in the tank or it can create a siphon and make the water to run a small amount nostop. Hope this helps you. Have a good day and thank you.
Apr 30, 2011 | Home
When i discale my Z5 the machine stops after cleaning the caputower and then stays in his programm and doesn't go fearther. What can I do to make the programm go to the end.
Be sure to measure up the correct amount of water before starting up the descaling program. It should be 600ml. Then be aware that the program takes about 45 minutes, and is in two steps. The first 35 minutes is for the 600ml in the watertank. You will then be asked to empty tray, and fill watertank. You can now fill up the watertank with fresh, cold water. Then the machine will complete the program (about 10 minutes) with fresh water, rinsing the system.
So; Be accurate in measuring the correct amount of water (solvent)-600ml
and be patient, this takes about 45 minutes.
Apr 26, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Water continually running into my toilet bowl. how do i make it stop?
IF YOU PRESS UR BALLCOCK DOWN IN THE CISTERN YOU WILL STOP THE WATER DRIBBLING IN THE TOILET ,JUST VERY SLIGHTLY BEND THE METAL BAR IN THE MIDDLE AND IT WILL STAY DRIP FREE,OR PUT A LITTLE WEIGHT ON THE METAL BAR NEAR THE BALLCOCK...ROB
Sep 05, 2010 | Home
I've got a problem with my Saeco Vienna Digital. It says that I've got to fill the watertank and ventilate. But the watertank is filled, that little 'thing' in the corner of the watertank is still going up...
Check the end of the steam wand it might be blocked, if it is not, then remove the steam wand and check the top there is a small teflon insert (this part is in some models) remove insert and toss. If that does not solve problem then machine needs to be descaled.
Jan 12, 2010 | Saeco Vienna Digital Coffee Maker,...
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco royal professional aqua prima water filter
I think there should be a gasket in the watertank that the filter goes over.
/Mirran
Sep 25, 2008 | Saeco Royal Professional Espresso Machine
Watertank leaking
Miele prices are a little steep!
The parts for these machines are made by Saeco, if you are prepared to do a little research and looking at exploded parts diagrams you may save a lot of money by matching a part, start by trying here:
www.partsguru.com
Oct 19, 2007 | Miele CVA2660 Stainless Steel Coffee Maker
Home Logo
245 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
