Question about Sub-Zero Refrigerators
Not sure which model, but we bought it in 2004. It is a side by side. I have taken the ice drawer many times and not had a problem putting it back in, but it isn't going back this time.
I feel like I've tried it every which way, but nothing is working. The white plastic-y wirey thing at the back is out and the thing on the side is there, but I can't figure out how to make them be attached to the back lip of the drawer.
  • 1 more comment
  • Kari Winter
    Kari Winter Apr 15, 2015
    OK, just figured out it is a 642 if that helps.
  • Kari Winter
    Not sure why it says I stopped wanting an answer. Still need one. Did I somehow make it do that?
  • Kari Winter
    Kari Winter Apr 17, 2015
    Figured out the problem. The white flat thing behind the drawer had been pushed back, so it wasn't obvious that it was there and needed to be hooked onto. Once I saw that and pulled it out, everything worked.
  • 28 Answers
The bucket hangs on a cradle. Reach in and slide the cradle all the way forward then hang the bucket on to it.
Posted on May 23, 2015
Rotu
  • 175 Answers
SOURCE: Ice maker drawer for sub-zero 632
Look at both those tracks on each side. its likely one or both are cracked or broken. Each one has 2 screws holding it in. To put the metal hange back in the tracks, you must get new tracks (if broken/cracked) then hold the2 tracks onto the bucket carriage...then stick thewhole thing in as an assembly, hen put the 4 screws back in. there are 2 more small screws way in the back (one on each side), but they do not have to be removed, only there to guide the racks in properly. these tracks are only about 7 bucks apeice, and shouldn't take long to chamge. Good Luck!
Posted on Aug 16, 2007
Maanita
  • 1142 Answers
SOURCE: replacing the ice maker mechanism on a GE side by side
  1. Unplug the refrigerator.
  2. Remove the icemaker's front cover by unscrewing or prying it off as needed
  3. Remove the ice bin, shelves, and vertical partition.
  4. Remove remaining screws, disconnect the icemaker wires from the harness connector or socket, and remove the unit from the freezer.
  5. Remove the back access panel and any fasteners that hold the inlet valve to the refrigerator.
Posted on Aug 07, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
gtaplytmpt
  • 90 Answers
SOURCE: Freezer not making ice in Fridgidaire model PLH269ZDB2
Have you made sure the arm or flap attached to the ice maker is down? this little arm tells the icemaker to start making ice, or stops it when it is full or you are on vacation. Also, it's possible when you push the fridge back into place that you are crimping the water line shut. this last one happened to me when I moved into my house. I had tp hold the line up, then push the fridge back a little less thatn I had before. Don't forget to rate answer if it helps.
Posted on Jan 02, 2009
  • 93 Answers
SOURCE: whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Posted on Mar 15, 2009
A piece of plastic broke off of dispenser but ice maker was still working until it just stopped today. Now can not even slide drawer out. Like something is holding it in. Have taken out 100 times...
use a hair dryer,unplug the machine or if you know how to manually get it into defrost do that so it will help you melt out the ice that's holding it in place.or you can put a towel down and pour hot water on it to melt it out,whatever works.sounds like water might have leaked from ice maker and froze the draw in place.
Dec 21, 2017 | GE Profile¿ Arctica® Energy...
Our side by side electrolux refrigerator will not disperse cubed ice, only crushed. everything else works fine. Model number PRLS267ZAB8
Pull the ice drawer out and look for the small, metal "arm" that sticks out of the back of the outside of the drawer. Empty all the ice out and make sure this arm swivels freely. Sometimes it can get stuck.
Aug 29, 2010 | Electrolux Icon Professional Ice Maker...
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
How can I stop automatic ice maker from continually making ice?
There should be a metal wire that hangs over the drawer. When the drawer is full, the wire flips up and shuts off the ice maker. You have to manually lower the wire back down to restart the ice maker. It sounds like yours is hung up, missing or broken. Have you checked this?
May 08, 2010 | GE GSS22IFR Side by Side Refrigerator
Ice falls to bottom of frig when drawer is opened
If when your ice bin is pulled out it drags ice cubes from top of bin as I understand I would think that the sensor that tells the ice maker is not responding correctly. As I remember your model a PSS26MSRSS Profile/Artica has electronic Ice Makers that I hate and I think most people will agree that anything on a refrigerator electronic is a big mistake. All refrigerators have their problems but the electronic controlled models have so many complaints! Now I also noticed you did not confirm your model number so I need to ask is your model the PSS26MSRSS Profile? This is a lot of writing if I happen to be quoting a different model than yours, Thanks Sea Breeze
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Maytag refrigerator (model MSD2454GR)side by side. It has two problem. We cannot keep the icemaker working. Ever since we bought it, the ice maker will stop working. When it was under warranty, it...
So how many times has the ice maker stopped working? seems like you are having bad luck with these ice makers. One of the problems is the electronic modules on those models do that but I really don't know what may be causing yours to go so many times. yes the control board sometimes will stop them but it will stop a lot of other things too if that was the reason. Sounds to me the technician took advantage on that call just to put one in. The computer does have something to do with power but I think he or she took advantage of you. Now if you can pour tap water into the tray slots and it will freeze and drop the ice then the water control valve is the problem. You know I could make enough money just being honest with the customer. Try the water trick and let me know what happens and we will decide from there, OK? Thanks, Sea Breeze.
Dec 29, 2009 | Refrigerators
My galaxy ice maker stopped working. At first i thought it was just jammed. We cleared it of ice. We thought maybe the drawer wasn't put back in correctly, took it out and put it back. Worked for a little...
ck the temt of freezer . it must be 15 deg or lower . sounds like it 20 deg and is having a hard time. set freezer to lower tempt and clean the coils undr neath and make sure the fans both top and bottom are going . as no air flow no ice. or poor cooling .. **** hope this helps / feed back pls .
Dec 23, 2009 | GALAXY Microsystems 25.4 cu. ft....
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Subzero model 532
Fernando is right! Now I will put it in girl terms. The lip of the drawer (lip is at back of the drawer) rests on a white plastic thing. But when you take the drawer out completely, the white plastic thing retracts and just looks like the back of the fridge. So when you go to put the drawer back in, you see nothing to put the lip on. So pull the white plastic thing (it looks like a white plastic rectangle about the size of an envelope) forward and then hook the lip onto it and gently pull the white "augur" (the thing that senses when it's time to make ice) down and slide the drawer back in. My son figured this out from reading Fernando's solution. What a relief! Our model is a 561.
Nov 03, 2007 | Sub-Zero 632 / S
Refrigerators Logo
78 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
