What's your question? I just bought Finesse tv but it does show any channels its just blue screen only ive tried to do automatic channel preset but nothing happens
    Master:
  • 369 Answers
The blue screen shows that you do not have a signal coming into the TV. So it sounds like you have the wrong input selected and or no aerial connected. Check the manual look for the inputs menu any cycle through them. My best guess is the DTV (Digital TV) input is not selected or you have it selected but no aerial plugged into receive a signal.
Once you have confirmed this run the automatic channel pre-set again.
Posted on Apr 15, 2015
SOURCE: Channel changing on PROSCAN 32LA25Q
I had the same problem, what fixed it for me was to set auto scan to setup all the channels for me again. Another thing to check would be whether it is set up to use CATV or AIR.
Posted on Dec 30, 2007
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
full str pka
  • 14 Answers
SOURCE: no signal and blue screen
hello
i think you might have a blue screen of death on your tv
--full str pka
Posted on Dec 31, 2008
  • 92 Answers
SOURCE: olivia 42'' flat screen and cant get any cabel channels
make sure that you're not using a cable box. then when you do the channel scan, make sure that you pick cable instead of antena.
Posted on Jun 18, 2009
SOURCE: Dynex 32" 720 LCD HDTV - no channel listing after run auto scan?
Excuse me but the other answers are written by people who have not actually confronted the problem and are just guessing. They are all wrong. Here's the answer:
If your TV is expecting a TV input, it will keep searching for at least one TV channel on cable or antenna. If you only have a DVD player plugged in, for example, or if your cable is hooked up wrong, so there's no video signal on it, the TV will keep searching forever. (This is an unforgivable design flaw, by the way. But then, it was a cheap TV, wasn't it?)
To solve the problem, look at your remote control. You will find input buttons. Mine are small, along the top, right under the "power" button. Try pressing "video" for example, instead of TV. That stops the TV from hunting for TV channels.
Have a merry Christmas. Enjoy your new TV. Watch it in moderation and eat fruit and vegetables every day.
Posted on Dec 25, 2009
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
on the TV screen.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
channel reappears on the screen.
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
What buton do press to get the channels?
Hello
To tune the TV either with cable of trerrestrial antena, plug in the cable or terrestrial antena cable to the antenna socket of the TV and do the following.
on the TV screen.
channels.
OK.
Dec 16, 2010 | Emerson EWF2004 20" TV
Sanyo Plasma DTV turns it self on
No solution sorry but i have a problem too... I usually watch my tv on "dtv" now it just went black no channel is working it automatically went to "ATV" where the channels are fuzzy and my extra channels aren't working. I tried scanning on "DTV" for all the channels but automatically scanned and defaulted back to "ATV". Does anyone know how to fix this?
Mar 26, 2010 | Sanyo Televison & Video
RCA TV/VCR combo T13060GY won't go below channel 5
I had a similar trouble with a couple of tv sets, one was a Granada and the other a Sony, but once connected to the satellite or digi-box via the scart socket it seemed to concentrate it's mind and override all the channels - so the tv stops being a tv set but becomes a monitor displaying whatever analogue video signal the digi-box sends to it.
The channels should arrive from the satellite receiver/decoder box and that remote control is all you need and the only thing you need to touch the monitor tv for will be the volume...
Scart sockets and plugs are apt to become dirty and unreliable and are responsible for many problems, including once a blue screen.
May 28, 2017 | RCA T13060GY Combo
Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Mar 21, 2009 | Vizio VX20L 20 in. LCD TV
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Freeview box
After scanning the box should save the channel automatically. If the box does not save the preset after scanning channels, then it is probably faulty.
Some box has a pinhole reset button at the back, if you have this reset button keep it pressed with a pencil for 10 seconds to reset the freeview box.
If it does not work, the nbox is probably faulty.
With freeview you only pay for few scrambled channels, the most of them are free and do not need any additional fee.
Freeview is not available in all areas, check that you have freeview in your location, and that aerial is well connected to the box, otherwise not finding channels is normal.
Sep 05, 2008 | Televison & Video
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
