Question about Uniden Cordless Phone
Says line on hold how do i fix it - Uniden Cordless Phone
How to replace the oriface tube on a 2001 ford windstar
Remove condenser-to-evaporator refrigerant line. Separate line to expose fixed orifice tube. Pour small amount of clean refrigerant oil into cavity to aid removal. Engage Fixed Orifice Tube Remover/Replacer), hold tool body and turn "T" handle to draw out fixed orifice tube. To install, reverse removal procedure. Use new "O" rings coated with clean refrigerant oil.
Jan 25, 2013 | 2001 Ford Windstar
How to fix a leak in the transmission line at the radiator?
There should be a small o ring, likely got damages or dislodged.
May 05, 2012 | 1994 Jeep Grand Cherokee
My flat screen tv has different colored horizontal hold lines across my screen. Where is the button for horizontal hold?
Those colored lines are a bad panel. Is no button to make them go away. The only fix is to replace your panel. Would be more cost effective to replace the TV.
May 06, 2011 | Dynex DX-LCD37 TV
1991 Ford F150 XLT has a hole in the brake line down from brake fluid holder and sprays on engine when brakes applied. Is there an easy way to fix a hole like this?
Unfortunately no. The brake line holds about 4,500 - 6,000 lbs of pressure when your brakes are applied. The only for sure way to fix this problem is to replace the line itself. Trying to do a "quick fix" to your brakes is the worse thing you can do. You will put yourself as well as other lives at risk.
Sep 24, 2010 | 1991 Ford F150
Need to replace ac condensor on 1999 taurus how do you do it
If your AC system is empty...The condenser is in front of the radiator.
1. Use ramps or jacks or a lift to raise the car so you can work under it.
2. remove the splash guard under the radiator.
3. Remove the bolts holding the tranmission cooling lines. These also may also hold the bottom of the condenser on the AC line side. Move the cooling lines away from the AC lines.
4. Remove the nuts holding the AC lines to the condenser. You may have to hold the fittings with a vise wrench to prevent bending the pipes.
5. Remove the other lower condenser bolt and use the access holes to remove the top bolts holding the condenser.
6. Lower the condenser out.
Reverse procedure to install the new condenser.
If you have the correct tools, this is a fairly easy job.
May 28, 2010 | 1999 Ford Taurus
MY RYOBI 31CC 775R WEEDEATER WON'T START I REPLACED THE SPARK PLUG AND STILL NOTHING I DON'T THINK ITS GETTING GAS HOW DO I FIX OR REPLACE GAS LINES.
spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Jul 24, 2009 | Garden
If water line is frozen to ice maker, what is best way to fix?
take a hair dryer and hold it on the water line where it goes into the back of the freezer if this does not fix it then you might have todefrost the freezer
Jun 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Line 2 on Partner system is always on. This happened to line 1 last week, but same procedure does not work: (Feature 00 ; Left Intercom 2 times; #728
There is a short on the line holding it open. If it hasnt been fixed yet, call the provider of the phone lines.
May 01, 2008 | Avaya Lands Phones
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Uniden Cordless Phone Logo
53 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
