Question about Star Micronics TSP700 Thermal Printer
Pappir is comming out but no ink on it....its connected with pararell connector on w7
2 pararell lines on the screen.
What is the nature of these lines? Vertical or Horizontal? Provide more details please.
May 27, 2013 | Sansui Televison & Video
G6-2210us usb 3.0 Host Controller
w8 was day1, OS. per HP.com
HP does not support w7. on this LT.
w7 32bit or 64bit, ?????
so its doomed to fail.? sure, and so you discovered that.
you clicked, "load automatcially in DM" with or with out internet connected, (yes, be connected is always best)
there are only 3 ways to do this, (if possible at all, im a driver expert)
1: read the HP page, , no w7 there, zero support w7, checked.
2; open PC, read numbers off the chip, amazing no? find the chip?
3: or run the PCI scanner, I uses, and let that nice tool find the chip and its real maker name (code) and chip code.
bingo #3 is easy lacking HP.com support.
4: or ask on HP forum, well its there. ananswer.
so lets do HP first, HP.com
it says at HP.com that it came with W8.
so you downgraged it to w7, and HP dont support down grades.
my guess is w8 was infected, and you didnt reload, w8 from scratch using F11 key, Restore, Am I correct?
W7 lacks drivers for chips not invented back in 2009?
your pc is newer than 2009 , and W7 may have no drivers for it.
if you look close *(unlike my elitebook) the w8 has the usb3 driver inside windows,8 and 8.1 already. so no HP driver is offered.
then you go to W7 and expect to find it there,
here is how to use the PCI scanner a free program.
run this and it tells you every chip in the system.
almost. all.
PCIsniffer3.
http://www.pcdied.com/pci-101.html
then when you find, USB3,
get the 2 codes.
mfg maker code, and chip code.
with that we go to the actual MFG and find a driver.
warning
some chips in the HP are buried deeper and only HP drivers work
on my LT, the USB 3 is (usb2 is intel)
is NEC company
chip code 0194h= upd720200
wiki,
In April 2009, Renesas Technology and NEC Electronics reached a basic agreement to merge by around April 2010.
see , you need to know these facts to find drivers.
its not NEC now.
its Renesas, (mine , not yours, this is but 1 example)
some USB chips need a reflash, or have bad drivers.
last and best
see Pauls answer at HP
http://h30434.www3.hp.com/t5/Notebook-Operating-System-and-Recovery/HP-Pavilion-g6-2210us-Need-USB-3-0-Drivers/td-p/4691722
here is the header from INF file>: tells what is there.
; SMBUSamd.inf
; Installation file (.inf) for the AMD SMBus device.
; Copyright (c) 2008-2011 Advanced Micro Devices Inc.
[Version]
Signature="$Windows NT$"
Provider=%AMD%
ClassGUID={4d36e97d-e325-11ce-bfc1-08002be10318}
Class=System
CatalogFile=SMbusamd.cat
DriverVer=03/16/2011, 5.12.0.0015
[DestinationDirs]
DefaultDestDir = 12
[Manufacturer]
%AMD% = AMD.Mfg, NTamd64
and last
direct from AMD, (no virus bs)
I think this covers all SMbus chips. they made.
http://support.amd.com/en-us/download/chipset?os=Windows+10+-+64
May 03, 2017 | HP Computers & Internet
Aux input 200mv in pararell
Hello
What is the actual problem with your amp? Your problem post is not clear to understand. Please specify more with it. OK.
Nov 14, 2011 | CSi Speco PBM-30 2-Channel Amplifier
DOWNLOADED THE DRIVES FOR WINDOWS HP AND WHEN I OPEN IT UP TO USE THE SCANNER IT SAYS NOT INTIALIZED. SCANNER NOT FOUND. AND IT IS HOOKED UP WITH PARARELL CORD.
It's due to a port protection in microsoft systems after windows NT, old drivers can't use some hardware connected to some ports (ex: pararell port).
You need to set up your system so drivers can communicate with the hardware ports.
In this case you can use dlportio.dll and follow the next steps:
1) Open the zip file. 2) Copy the file dlportio in one of the following places a) c:\Windows\system32 b) c:\Windows c) The root directory of the affected application.
If it still doesn't work:
3) Reinstall the driver.
If problem still persists you can install some kind of DOS emulator, commonly used to play old abandonware games.
If you need more assistance please leave a comment.
Regards.
Oct 22, 2010 | HP Scanjet 4400c Flatbed Scanner
CAN NOT LOAD THE GAMEFROM THE CARD
clean out the game card , and the card port
May 26, 2010 | Nintendo DS Lite Console
How bridge to 1 ohms
for bridge to 1 ohms you need to connect 3 speaker in pararell
Apr 09, 2010 | Hifonics Brutus BX 2005D Car Audio...
The cartridge bay goes crazy and slams both sides of the printer. Thus, this will not let me print. I was printing fine, and then I heard a slam, and a notification popped up sayin there was a problem with...
Clean encoder strip, thin plastic strip runs width of machine pararell to silver scan rail. Ensure it is running threw carriage smoothly otherwise the light that read it is dodgy, this will be unecomical to fix unless dirty strip
Nov 07, 2009 | Lexmark Z715 InkJet Printer
Need manual for Bionaire W7
http://www.appliancefactoryparts.com/content/pdfs/109365-1.pdf
here is the manual for your w7. if you have anymore questions please let me know.
Mar 30, 2009 | Bionaire W7 Humidifier
51 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
